Overheating
Old Mar 10, 2009 | 09:02 AM
02speedway's Avatar
02speedway
Default Overheating
The fans on the car on not coming on and the temp went up to over 225 while sitting in traffic after I got the car back from the shop, but once the air got moving it dropped to 169 at crusing speed 70 mph. Do you think that a fuse is bad or did they accidently unplug the fans?
Old Mar 10, 2009 | 09:21 AM
fdxpilot's Avatar
fdxpilot
Unless your PCM has been reprogrammed with new fan temps, the fans won't come on until 226 deg. They then come on low speed until 235 deg, where they switch to high. However, if you turn on your AC, the fans will run anytime the coolant temp is 165 or higher and speed is below 35mph or so.
Sounds like you have a 160 deg thermostat , but no fan reprogramming. Your system is working normally. All the thermostat will do is control the min temperature of your cooling system once it has reached opening temperature. It will do nothing more if the load on your system is enough to make the temps go above min operating temperature, as it is already wide open. In stop and go traffic, your temps will usually go up to at least the min fan temperature. (226 stock.)
Old Mar 10, 2009 | 09:58 AM
02speedway's Avatar
02speedway
Yeah that is what I thought but I turned the ac on and the fan didnt come on unless you cant hear it when the hood is open maybe im missing something. Then when I had the hood open you could hear a boiling sound coming from the overfill.
Old Mar 10, 2009 | 10:17 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the fuses then check the ground pack at the right forward frame rail on top adjacent to the hood riser. The fan(s) grounds go through that. If its lose, they won't work. Also check the fan(s) electrical plugs themselves. If either of the two of them are off, neither will work in low speed mode.
Old Mar 10, 2009 | 10:58 AM
SKF engineer's Avatar
SKF engineer
At low speed it's nearly impossible to hear the fan noise over the engine noise. Not recommended since you could hurt your hand but I sometimes stick my hand down there behind the fan when I have the AC on to see if the air is moving and sure enough there is a light breeze.
Old Mar 10, 2009 | 11:49 AM
dgrant3830's Avatar
dgrant3830
Here you go
Old Mar 10, 2009 | 01:12 PM
02speedway's Avatar
02speedway
Thanks for all the advice will check tonight, this is why I love having a vette because of all the help you get.
Old Mar 10, 2009 | 08:59 PM
c5vetteman99's Avatar
c5vetteman99
My fan doesn’t come on until around 225-230. If you turn the heat on, brining outside air in, it will cool the temp. down by brining the hot air out of the engine compartment.
Old Mar 10, 2009 | 09:52 PM
Bill Dearborn's Avatar
Bill Dearborn
Unless you had the fans programmed to come on at a lower temp than stock it doesn't sound like anything is wrong. This isn't a 1960s car and is designed to run at the temps you saw.
Bill
Old Mar 11, 2009 | 01:21 AM
Point & Shoot's Avatar
Point & Shoot
I agree - 225 at idle is noooooo problem - when the low speed fan kicks in at 226, you should see the needle drop back down till it cuts off at around 216.
On super hot days in Tampa, sitting it traffic not moving without AC on, sometimes even the low speed fan is not enough, temp will go to 235 or so, then the high speed fans kicks in and will draw the temp down easily.
The hardest thing to accept is that stock, these cars have a temp range of 192 to 235 or 43 degrees and everything is
As long as they are turning on just relax and let it do what it was designed to do !!
To Overheating
