Corvette Tunnel Plate...
It is approx 1/8" thick aluminum and at least twice as thick as the stock one. While not as thick as the aftermarkets, to me the saved $ are more important. The noticeable difference for me was that my removeable roof stopped creaking after I installed it.
It bolts right up and costs about $68 shipped.
So what is what I want called?
PS and I am thinking about using the c-6 plate along with my stock on just to get some more heat resistance.
I am not sure the exhaust system has to be lowered but if it does I would just un-do the 4 bolts at the muffler hangers and the two bolts at the rear of the torque tube and let the system sag a bit while I undo those 30 sum bolts, slide the old one out and the new one in.
Again I have not done it yet but will be doing it when I install my OBX headers in the next few weeks.
Oh!!
Well to late, I have ordered it. I am still going to look at using the C-6 plate along with the stock plate. maybe put some insolation between them. But till I get them both off I won't know exactly what I will be doing.
I installed a 1/4" tunnel plate myself and the car 'feels' a little stiffer, but I have no real means for measurement. It may be more 'mind' than 'matter'.
However, I have reduced interior heat. Here's an overview:
As you know, the primary contributor to heat in the vehicle comes from the exhaust tubes in the tunnel.
You can install a heat barrier (there are many types) between the floor / tunnel sides and the carpet, but this adds bulk to an already space-challenged situation, and eventually the insulation material heats up and begins to radiate heat on its own.
Insulated tunnel plates may help, but they only block and do not remove the heat.
You really need some method for removing the heat mechanically.
If you take a look at where the mufflers and cat converters are located, you will see that GM has installed metal heat shields that are spaced away from the surface that they are protecting.
The air space allows for a mechanical removal of heat (as the vehicle is driven) instead of attempting to block the heat with insulation.
So, following the GM engineered model, I designed an aluminum plate to surround the exhaust (on three sides) while still leaving a 3/8" air space between the plate and the tunnel sides and the tunnel closeout panel.
Designing the plate and having it fabricated was a little tricky, but there is adequate room if you measure carefully.
I took heat measurements at the base of the tunnel before and after I installed the shield and I measured a 30 degree heat reduction under medium load conditions (driving in hilly areas) and a 20 degree heat reduction when cruising (flat roads).
If you are interested in more detailed information about the design, send me a PM.
