Corvette Tunnel Plate...
Old Mar 11, 2009 | 12:22 AM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
Default Corvette Tunnel Plate...
Anyone with one of these installed I was wondering what your thoughts were about it. Have you noticed a difference? Is it worth it? I get wheel hop do you think this will help reduce it at all? Header install coming soon so it would make sense to throw this in at the same time.
thanks!
http://www.southerncarparts.com/corv...eel-p-243.html
Old Mar 11, 2009 | 12:58 AM
Point & Shoot's Avatar
Point & Shoot
Save your money and order a C6 tunnel plate from Gene at GM Partshouse.
It is approx 1/8" thick aluminum and at least twice as thick as the stock one. While not as thick as the aftermarkets, to me the saved $ are more important. The noticeable difference for me was that my removeable roof stopped creaking after I installed it.
It bolts right up and costs about $68 shipped.
Old Mar 11, 2009 | 01:06 AM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
Aha... That would be nice too. My roof does creak a little here and there especially in the cold!
Old Mar 11, 2009 | 01:33 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I'm doing one with insulation to fight the heat in the console area. A lot of headers put the cats right in the tunnel area.
Old Mar 11, 2009 | 01:42 AM
Last C5's Avatar
Last C5
They reduce a lot of heat. And with headers they're almost a necessity in my book.
Old Mar 11, 2009 | 01:51 AM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
If I do a C6 one is there someone that sells insulation to put over over it does is come with it on already? Or at that point is it just better to get an aftermarket one?
Old Mar 26, 2009 | 09:35 AM
Corvette Don's Avatar
Corvette Don
You could have it ceramic coated. I have 3 C6 plates that I am going to rivit together and ceramic coat (myself), 3/8" plate
Old Mar 26, 2009 | 09:38 AM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
I actually scored a good thicker ceramic coated one on ebay! It's in now as long as the headers. I can't believe how thin and crappy the stock one was!
Old Mar 26, 2009 | 11:05 AM
kart76's Avatar
kart76
Who does ceramic coating? Or how is it done?
Old Mar 26, 2009 | 02:23 PM
minitech's Avatar
minitech
Maybe consider ceramic coatings on all first and then rivit together.
So you get ceramic-metal-ceramic(double layer)-metal-ceramic(double layer)-metal-ceramic.
If done after you get ceramic-metal(3 layers)-ceramic
Old Mar 26, 2009 | 03:36 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I agree headers produce alot of heat that end up in the cabin.
This is a cheap way to stay cooler. ( order the ceramic coated
plate, well worth the money ) Plus it's easy with the stock
headers off but there are a lot of nuts!!!!!!
Old Mar 26, 2009 | 03:53 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
The thread also questioned if the tunnel plate would help with wheel hop. In my experience it will do little; however, a DTE transmission brace will help greatly. It eliminated mine totally. Cheers
Old Mar 26, 2009 | 04:02 PM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
I think that might be installed in the near future.
Old Mar 26, 2009 | 04:09 PM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
Here is the tunnel plate I got installed if anyone else that has been checking this thread out is considering buying one...
http://cgi.ebay.com/ebaymotors/Corve...8#ht_807wt_930
It seems to be doing the trick of keeping the heat out. I think the ceramic coating def helps. I believe he has a 3/8 thick one too.
Old Mar 26, 2009 | 04:22 PM
stngh8r's Avatar
stngh8r
I plan to take my factory plate to the local machine shop and have them use it for a pattern and cut out a new one for me with 1/4". I may shoot it with some coating of sorts, but probably not. I think the extra thickness of the metal will help with the heat some.
-Side Note- I wraped my pipes with header wrap from the header collectors to about 1.5 - 2 ft. back on the intermediate pipe and that helped with the heat substantially.
Eric
Old Mar 26, 2009 | 09:30 PM
PewtVette's Avatar
PewtVette
I bought a plate and wrapped it myself. I also insulated the tunnel:
Old Mar 26, 2009 | 09:35 PM
tiojames's Avatar
tiojames
Put mine on about two years ago. I also put the aluminum heat stuff I had left over from doing the inside of the car up in the tunnel when I had it open.
To Corvette Tunnel Plate...
Old Mar 26, 2009 | 09:44 PM
gpotski's Avatar
gpotski
I used Elite Engineering's ceramic coated steel plate, and it lowered the heat transfer to the passenger compartment and it tightened up the frame alot. The car felt more steady on uneven road, going over manholes, etc.
Well worth it.
http://www.eliteengineeringusa.com/
Old Mar 26, 2009 | 10:35 PM
ljthe2nd's Avatar
ljthe2nd
What did you use for the insulation?
Old Mar 26, 2009 | 10:41 PM
happa's Avatar
happa
Man I learn something new everyday
