Problem: Plastic ring around ignition switch
Old Mar 11, 2009 | 09:05 PM
c5man99's Avatar
c5man99
Default Problem: Plastic ring around ignition switch
I had to remove the driver side dash and when I put it back together, the ignition switch is binding.........have taken the dash apart many times over the last 10 years...........never this problem! The switch works, just very tight.
Thanks,
Old Mar 11, 2009 | 11:15 PM
happa's Avatar
happa
e did that before, not sure what happen. I took it apart and put it back together and it was fine weird
Old Mar 12, 2009 | 03:36 AM
briann510's Avatar
briann510
Last month when I had my lower panel off under the steering column my ign key switch starting binding afterwards. I took the panel back off and found the switch cover surround had moved off center a little bit in the recess in there and was making it bind a little bit.
Old Mar 12, 2009 | 01:36 PM
c5man99's Avatar
c5man99
Thanks guys.........I kinda figured that but DIDN'T want to tear it down again!
To Problem: Plastic ring around ignition switch
