The 41-985 is now what GM calls for. The gap also changed from .060 to .040. Below is from the service manual.
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
Since we're on plugs. I bought my C5 new in 99 and it came with NGKTR55IX from the factory. At 30K miles I replaced them and installed the same plug. I drove 30K the first year. Just wondering is this still the recommended plug for the 99 C5? Thanks vettdvr
My only concern with this plug is I pulled all 8 at 30,000 miles and found the iridium tip missing from 2 of the plugs. Where did it go?
Through the cylinder, valve, exhaust or burned off? I am concerned about material failure in the NGK. Granted this was back in 99 and they may have improved. It would be interesting to see what experience others have with this plug. Due to the failure of the tip is why I was wondering if there was a AC? plug
Doesn't mean the NGK's are bad I have a set running now. But still concerned about the failure.
To my knowlwedge all OEM plugs thru at least 2000, maybe longer, were Platinum plugs. These are the ones that may have had the Platinum pads missing from across the electrode. Gm changed to Iridium plugs around 2003?
And GM wasn't using NGK as OEM either. They were Denso.
