What is the HIGHEST C Ratio???
Old Jan 27, 2002 | 03:48 PM
ZO6LS6's Avatar
ZO6LS6
Default What is the HIGHEST C Ratio???
That you can go with on a stock Zo6, '01 model........without altering the PCM, etc............?? :rolleyes:
Old Jan 27, 2002 | 04:56 PM
rwj383's Avatar
rwj383
Default Re: What is the HIGHEST C Ratio??? (ZO6LS6)
why do you want to raise the compression ratio? nothing to gain unless you get up into the ranges requiring high octane fuels. there's a lot involved to deal with a higher compression. also, just to be clear, if you raise the compression, the motor will no longer qualify as 'stock' as you mention.
Old Jan 27, 2002 | 05:14 PM
C5 Tweaker's Avatar
C5 Tweaker
The factory tuning has the timing on the edge of knock. If you increase the compression without adding a cam (which lowers the effective compression), you can end up with GOBS of knock.
I did 11:1 heads before my cam, and had to run octane booster to make it driveable until I installed the cam.
To What is the HIGHEST C Ratio???
