Programming Remote Problem... HELP!!
Old Mar 12, 2009 | 05:32 PM
jjnielsen82's Avatar
jjnielsen82
Cruising
Default Programming Remote Problem... HELP!!
I purchased a keyless remote and my buttons to the right of my gauges are not working.... Is there any other way to program the remote without those buttons working? Let me know.
Old Mar 12, 2009 | 05:52 PM
jdmvette's Avatar
jdmvette
Night Owl for life
you can't use the buttons on your DIC?
Old Mar 14, 2009 | 01:24 AM
jjnielsen82
Cruising
for some reason they do not work... i have already removed my gauges and inspected the connections and they appear fine. Any other way to program the remote?
Old Mar 14, 2009 | 02:35 AM
Slick Rick's Avatar
Slick Rick
Yea aim it at car and hold lock and unlock buttons at the same time until the horn honks and your done.
Old Mar 14, 2009 | 09:08 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I don't believe that will work with a new fob, only with one that was previously programed to the car. If it did then anyone with a fob could open any car
I think you're going to have to get the button problem fixed before you can program the new fob.
Old Mar 14, 2009 | 11:20 AM
65GGvert's Avatar
65GGvert
Every time the question is asked about programming a new remote, someone comes up with the "hold the lock and unlock". If that worked everyone could unlock every other C5 in the world. That only resyncs an already programmed remote.
You'll have to fix your DIC buttons first, then make sure you bought the correct remote, then run the program to match it to your car.
So, does your car always display mileage? Pressing the reset button on the DIC doesn't do anything? If you ever get a message, you won't be able to clear it until you get that fixed if that is the case.
Old Mar 15, 2009 | 02:15 AM
jjnielsen82
Cruising
it displays the mileage ever so often. right now it flashes that one of my tire is low and one is filled too much... these codes are annoying. When i push the buttons it changes nothing.
Old Mar 15, 2009 | 06:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
ouch, that's a new one on me. in my several years on the forum, i can't recall hearing this problem before.
try posting this in the c5 tech section too.
To Programming Remote Problem... HELP!!
