Car troubles... Please help!
Old Mar 12, 2009 | 11:41 PM
cvalvarez77's Avatar
cvalvarez77
Default Car troubles... Please help!
Hey guys,
Me and a buddy of mine just installed my new clutch and everything seemed fine until I was driving back home. About 3-5 miles into my drive home, the security light starts flashing and the car starts to jerk back and forth as if it were running out of gas and then finally died on the side of the road.
As of now it is sitting in my driveway with a new clutch and a broken heart. The engine will turn over but it won't idle at all and even if i get on the gas it dies out regardless. Any ideas or suggestions??????
Old Mar 13, 2009 | 12:08 AM
golfinz's Avatar
golfinz
Any codes?
Old Mar 13, 2009 | 03:35 AM
cvalvarez77
Ttt
Old Mar 13, 2009 | 04:29 AM
dougbfresh's Avatar
dougbfresh
If the security light is ON, why do you think it has ANYTHING to do with your clutch??? Maybe it's THE SECURITY SYSTEM!!!!!!!!!! Once the systems kicks in, it's going to cutoff the fuel.
Old Mar 13, 2009 | 08:49 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Need to check your clutch assembly procedures somthing else went wrong during your assembly.
Old Mar 13, 2009 | 10:58 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the battery and battery to starter connections too. Ignition switch?
Old Mar 13, 2009 | 01:24 PM
Oldvetter's Avatar
Oldvetter
Originally Posted by golfinz
Any codes?
This should be the first thing you do. Pull the codes using your DIC. Use search if you don't know how to do this.
Old Mar 13, 2009 | 03:10 PM
97camaro's Avatar
97camaro
Clean the MAF Sensor with MAF cleaner.
Old Mar 13, 2009 | 03:32 PM
dougbfresh's Avatar
dougbfresh
-WHAT does this have to do with the SECURITY LIGHT?
To Car troubles... Please help!
