Holley Intake!!!!
Old Jan 27, 2002 | 06:45 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
Default Holley Intake!!!!
I just ordered one for myself!!!Only $50 more then the LS6 I was going to order.
Old Jan 27, 2002 | 06:58 PM
cjones's Avatar
cjones
Default Re: Holley Intake!!!! (Slammed Vette)
Better promise to show some before and after dyno sheets.
Old Jan 27, 2002 | 07:15 PM
99 Corvette's Avatar
99 Corvette
Default Re: Holley Intake!!!! (cjones)
Dyno sheets would be very :cool:
Jerry
Old Jan 27, 2002 | 07:16 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In IV Veteran
Default Re: Holley Intake!!!! (99 Corvette)
What are the claimed advantages?????????????
Old Jan 27, 2002 | 07:21 PM
Godspeed's Avatar
Godspeed
Senior Member
How much does it weigh compared to the LS6 intake?
Old Jan 27, 2002 | 09:53 PM
John's vette's Avatar
John's vette
I understand you can polish these. Can't wait to see a high polished one installed.
Old Jan 27, 2002 | 10:44 PM
jeffh355's Avatar
jeffh355
Default Re: Holley Intake!!!! (John's vette)
Looks :cool: , but would really like to get some feedback from someone who has one on their car.
Old Jan 28, 2002 | 12:45 AM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: Holley Intake!!!! (jeffh355)
I wonder if LPE is going to use this intake as part of his packages? If John helped design it, I would think he would use it. Any thoughts???
Old Jan 28, 2002 | 01:18 AM
pkmoose's Avatar
pkmoose
ditto :) nice looking manifold
Old Jan 28, 2002 | 11:50 AM
Chris@SD's Avatar
Chris@SD
In stock form, I do not believe that there are any advantages in performance. What you will get is the ability to either extrude hone(port) or acid port the intake to a larger size. The LS6 intake is a pretty good intake as it is. For the large cube engines out there, it might lack a LITTLE in the plenum volume.
Good Luck and I am waiting as patiently as everyone else for the results.
Thanks,
Old Jan 28, 2002 | 01:20 PM
Gramps's Avatar
Gramps
Default Re: Holley Intake!!!! (Buckmaster)
Just talked to my "flow" guru. His thought is that the aluminum will act as a heat soak and caus "overatomization" (word?) of the fuel and end up in a lean mixture state, leading to spark retard and power loss. I would be curious to hear John Lingenfelter's comments on this.
[Modified by Gramps, 1:12 PM 1/28/2002]
C5Longhorn's Avatar
C5Longhorn
So the only advantage is the ability to port and polish. I agree, the LS6 will work fine for most people. Also, how much more does the Holley weigh?
Old Jan 28, 2002 | 03:17 PM
Chris@SD's Avatar
Chris@SD
Default Re: Holley Intake!!!! (Gramps)
How can the aluminum intake cause over-atomization(never heard this one?!?!) when the injector is aimed at the back of valve?!?! 99% of the intakes ever made have been made of aluminum???
I really do not think there is anything there....
Old Jan 28, 2002 | 06:59 PM
Slammed Vette
I have plans on having this one ported to match my heads when it gets here.Plus,I figured it would be worth it to get it now seeing I have a big cube motor in my future.The main thing is it actually was less then $50 more then the LS6 intake shipped.I will post results and pics of it when I get it installed.It won't be to easy to tell the gains seeing I'm doing heads and cam at the same time,but will post numbers anyway.
To Holley Intake!!!!
