Turn Signal
Old Mar 14, 2009 | 01:24 PM
dberry08's Avatar
dberry08
Default Turn Signal
I searched all over, couldn't find anything on how to replace a front turn signal. Can anyone offer advice, I'm guessing it is not much different than how you replace the fog lights. Thanks in advance....I'm not looking for the process, just the part #
Old Mar 14, 2009 | 01:44 PM
jrose7004's Avatar
jrose7004
There's an access panel right below it.
Old Mar 14, 2009 | 02:27 PM
happa's Avatar
happa
and have some patients and get the front of the Vette high up so you can get to the bulbs easy. If you lived near me you could come by and use my lift or if you know someone I would use it. Would be a lot easier that way. Good Luck!
Old Mar 14, 2009 | 02:29 PM
dberry08's Avatar
dberry08
can't just take the headlight plastic thingy(technical term) off and reach it that way?
Old Mar 14, 2009 | 03:13 PM
ICUALL's Avatar
ICUALL
Default Download and open in word
http://www.c5help.com//Turnsignal_stalk.doc
Old Mar 14, 2009 | 03:36 PM
dberry08's Avatar
dberry08
Nice write up, but I'm lookin to replace the bulb
Old Mar 14, 2009 | 04:59 PM
DeeGee's Avatar
DeeGee
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It comes out by turning the bulb holder a ¼ turn counter clockwise but it has a plastic clip which you need to squeeze to release it. Here’s how the bulb fits into the lamp unit. The DRL bulb is the lower of the two.
Here’s the light socket. This one’s after market but it gives you the idea. You can see the clip you need to squeeze.
Change the bulb. It’s a push fit into the lamp holder. Push it home firmly but don’t handle the glass. Use latex gloves if you have them. Reseat the bulb holder and turn clockwise until it clicks back in place. Put the plastic headlight housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
It’s a 10 minute job. Some guys have had the lights close if they’ve taken a while to do the fix. If you’re worried about that, disconnect the battery once the lights are up.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
Old Mar 14, 2009 | 10:58 PM
dberry08's Avatar
dberry08
Thanks, I even drove to the Chevy dealer and they didn't know the part #, great write-up too.
Old Mar 15, 2009 | 12:44 PM
eddy20's Avatar
eddy20
Is this write up to change the Turn indicator bulb or the headlight bulb? sorry but it's confusing to me!
Old Mar 15, 2009 | 01:26 PM
DeeGee's Avatar
DeeGee
This is for the turn signal bulb
Old Mar 15, 2009 | 01:28 PM
DeeGee's Avatar
DeeGee
You can get the bulbs at Autozone. A 3057NA works too
Old Mar 15, 2009 | 02:09 PM
eddy20's Avatar
eddy20
Default Crazy Turn Indicator?
Thanks, would the burned out bulb cause the inside turn flasher indicator to go crazy and blink and click real fast or is this a separate issue?
Old Mar 15, 2009 | 02:13 PM
dberry08's Avatar
dberry08
yeah it does cause it to flash fast. Mine started flashing fast, turned the signal on, checked the back, they were fine, looked up front, and it was out.
Old Mar 15, 2009 | 02:35 PM
DeeGee's Avatar
DeeGee
Thats how the car tells you the bulb is out
Old Mar 15, 2009 | 07:35 PM
eddy20's Avatar
eddy20
Pulled out the bulb and it was still burning, but put the new one in anyway, but the same results. Could I have shorteed the new bulb by plugging it into the live socket? Or a bad new bulb? Or do i have another issue? So the bliker in the rear goes fast as does the dash indicator, but still no front turn singal light?
Old Mar 15, 2009 | 08:06 PM
ICUALL's Avatar
ICUALL
Had a similar problem try turning the bulb around in the socket. Sounds crazy but it fixed mine. If that doesn't work you need to use a meter to read if you have 12 volts at the bulb socket.
Old Mar 15, 2009 | 11:28 PM
eddy20's Avatar
eddy20
Default Thanks to the members of the Corvette Forum!
Thank you both Dee Gee (great write up!) and ICUALL! Well took out the bulb and switched it did not make any difference, but found out I did not have the bulb inserted deep enough, once pushed all the way home it worked and it is a 10 minute job although remember to open the hood to allow more room for your arm.
To Turn Signal
