torque converter (problem)
Old Mar 17, 2009 | 09:34 PM
marcussmith28's Avatar
marcussmith28
Default torque converter (problem)
All right guys here is my question. I had a ss3200 stall 3.90 gear and a tune, ok now when i drive down the road my torque don't want to lock up pass 45 mph. Help me out.
Old Mar 17, 2009 | 09:43 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Assuming that the install was properly done, your misfire tables in the tune may need to be adjusted to higher values till the no lockup condition goes away. I had mine set to max with the intention of working it down to lower levels at some point. HTH
Old Mar 17, 2009 | 09:51 PM
marcussmith28
If the stall was not installed right then it would not work, It really just goes one way, if its not right it will not bolt in. Because if the stall is not all the way in you will have clearance issues.
Old Mar 17, 2009 | 10:05 PM
marcussmith28
One more thing, i did not do a computer relearn could this have anything to do with it.
To torque converter (problem)
