Are LS1 and LS6 pushrods the same part?
Old Mar 18, 2009 | 09:38 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Are LS1 and LS6 pushrods the same part?
Reason I ask is because the LS6 cam has a slightly smaller base circle from what I've read. I'm going back to stock and collecting parts. Just want to check if LS1 pushrods are the same as the LS6.
Thanks,
Brian
Old Mar 18, 2009 | 11:00 AM
voda1's Avatar
voda1
Same pushrod. GM compensated by using longer valves.
Old Mar 18, 2009 | 11:36 AM
Cobra4B's Avatar
Cobra4B
So... if I'm putting a '02-'04 Z06 camshaft in a 2001 Z06 will I have pre-load issues? Does the '01 have the longer valves like the '02-'04 car?
Old Mar 20, 2009 | 10:52 AM
voda1's Avatar
voda1
01 does not have the longer valves. Some over on LS1Tech run 02 cam with stock length pushrods and have no problems. Don't know if GM decided it needed more preload or a better rocker wipe pattern. Instead of pushrods you could buy some thin 040 Cometic head gaskets to increase the preload as well as the compression ratio.
Old Mar 20, 2009 | 11:27 AM
Cobra4B's Avatar
Cobra4B
10-4... I don't want to pull the heads. I'll put it in and see what happens. If I don't have sufficient pre-load I can throw the 7.4s in that I have in there now w/ my G5-X2 cam.
Old Mar 20, 2009 | 06:34 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
funny, nobody ever mentions this when buying used 243 heads; don't have the spec in front of me for the valve delta
hyd. lifters are cool
Old Mar 20, 2009 | 07:25 PM
Cobra4B's Avatar
Cobra4B
Steve... you saying they'll make up for the slight difference?
Old Mar 22, 2009 | 05:12 PM
SteveDoten's Avatar
SteveDoten
I'm not a pro motor builder, but it's been done a lot
99% of the time 7.4's work in any Z06
I haven't done 100's of cam swaps like others though............
To Are LS1 and LS6 pushrods the same part?
