P 0153 Help
Old Mar 21, 2009 | 01:03 PM
z06sicz's Avatar
z06sicz
Default P 0153 Help
Installed long tubes and an X with no cats. Tuned out both banks 1&2 sensor 2's. Running the rear o2's up from with the adaptor plugs from the LG kit. Car was running great. Took it out for a good drive, did some blasts, and all was well. Went WOT through the gears and brought it home. Just before I went to park it in the garage it started to run very rough. Threw code P0153 slow response Bank2 Senor 1. Car will start and run for a second very rough and die out?
Bad O2 on driver side??
2002 c5Z with LG street series headers X pipe no cats. Yellow terra rockers, comp springs, Ti retainers, and harden push rods. Zip tie mod and K&N filter.
Old Mar 21, 2009 | 01:11 PM
z06sicz's Avatar
z06sicz
Got the car up and gave it a look. I didn't see any burned wires on the sensors. Car and senors have about 10k miles on them.
Old Mar 21, 2009 | 08:14 PM
Rob's 73's Avatar
Rob's 73
My guess is that you have a cat back as well. I had the same problem after I added LG Streets to my Borla Stingers. I think the exhaust is too free flowing and not allowing the O2s to retain enough heat. My Borlas droned too much with the headers so I switched back to the Ti's and the problem went away.
Old Mar 23, 2009 | 10:36 AM
z06sicz's Avatar
z06sicz
I don't have a cat back, it's the stock Ti system.
I found the problem! It was a BROKEN comp 918 spring on the intake valve
Changed to REV duals for insurance
To P 0153 Help
