Rocking seat fix
Old Mar 22, 2009 | 12:36 PM
capt1mike's Avatar
capt1mike
Default Rocking seat fix
I have seen the post on here , but now i can not fine it. please help Thanks
Old Mar 22, 2009 | 12:51 PM
nextime's Avatar
nextime
Search "rocking seat fix" there probably are well over 100 posts on the subject, that is how I found them.
EDIT.... Search feature really sucks here cause now I cant find the posts. I searched, rocking seat fix, rocking, seat fix and they all came up with 10 pages of posts to sort through. I searched in the C5 forums only.
Old Mar 22, 2009 | 12:57 PM
nextime's Avatar
nextime
Try this link, I dont know why it wont search better than this.
http://forums.corvetteforum.com/sear...rchid=10085512
Old Mar 22, 2009 | 01:12 PM
MagRedConv's Avatar
MagRedConv
Check out the Ultimate DIY sticky
capt1mike's Avatar
capt1mike
Default rocking seat fix
Thanks, But I still can"t find the past
Old Mar 22, 2009 | 01:57 PM
xboxexpert's Avatar
xboxexpert
http://www.lieblweb.com/TechLinks/Co.../C5SeatFix.htm
Old Mar 22, 2009 | 02:01 PM
timemender's Avatar
timemender
You’re "right on" MagRedConv – Links below to help the “search challenged” ----
It is in the “Ultimate DIY Thread” as MagRedConv stated.
It is called “Rocking Seat Fix” in the intro – the post, listed in the intro is ONE POST NUMBER OFF –
Links below to help the “search challenged” ---- ALL THREE PAGES ---
http://www.lieblweb.com/TechLinks/Co...C5SeatFix2.htm
http://www.lieblweb.com/TechLinks/Co...C5SeatFix3.htm
EDIT - All this typing and xboxexpert beat me to it
Old Mar 22, 2009 | 02:20 PM
xboxexpert's Avatar
xboxexpert
Old Mar 22, 2009 | 11:18 PM
Internets_Ninja's Avatar
Internets_Ninja
i tried this fix. Did not work for me. maybe I did something wrong?
Old Mar 23, 2009 | 12:21 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Fix worked great for me. Some have reported less than stellar results. In my case the rubber on both sides of the blocks was totally gone so that was the problem.
Old Mar 23, 2009 | 12:30 AM
AviatorVette's Avatar
AviatorVette
guys my driver side seat doesnt respond to any of the controls its stuck in front and i want to move it back, its not the wiper remote control because i plugged it in the other side and its perfectly fine on the passenger side.
Old Mar 23, 2009 | 09:19 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
these are the buggars that cause the problems.
Old Mar 23, 2009 | 09:58 AM
xboxexpert's Avatar
xboxexpert
Where did you get replacments and what are they called.
Old Mar 23, 2009 | 12:18 PM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
They are called junk. You posted the fix thread just buy the nylon washers from ACE.
Old Mar 23, 2009 | 08:21 PM
Tyke's Avatar
Tyke
I jsut fixed mine last week with the nylon washers....not rocking AT ALL, seats are like new again....My rubber stoppers were completely disintegrated, all was left was dust!!
Follow the isntructions, dont leave any loose space in the little metal box, and u will have no rocking seat!
Old Mar 24, 2009 | 12:51 AM
white90conv's Avatar
white90conv
There is another problem that can cause the seat to rock. On mine, the rubber parts were perfect. But one of the motors was a bit loose where it attaches to the frame of the seat. I managed to tighten it a bit but the problem came back.
Old Apr 12, 2009 | 01:20 PM
Armedruby's Avatar
Armedruby
Got the parts to fix mine, but I'm looking at the DIY fix and going DAYUM! I'm not sure if this is what's wrong with mine or not. I wouldn't say mine rocks, more like slides forwards on braking and then backwards on acceleration. It seems like it moves an inch or more in each direction. Those washers are only 1/8 inch thick, so if they were gone, wouldn't you only have 1/8 in movement?
To Rocking seat fix
Old Apr 12, 2009 | 01:50 PM
nextime's Avatar
nextime
If it is 1 inch in each direction you need a new seat bracket cause something is wrong and it is not safe to drive your car like that.
Old Apr 12, 2009 | 02:00 PM
Armedruby's Avatar
Armedruby
Tearing into it now to check. Stay tuned.
Old Apr 12, 2009 | 02:03 PM
Armedruby's Avatar
Armedruby
Okay, I can sit in it and pull myself forward. Never tried to measure it while driving, but it felt like an inch.....but it's more like 1/4 inch.
