ZR-1 Suspension
Old Mar 23, 2009 | 02:35 AM
C5Natie's Avatar
C5Natie
Default ZR-1 Suspension
Quick question guys, will the new ZR-1 swaybars fit a C5? Couldnt find an answer with the search engine. Also, whats wider, Z06, Z51 or ZR-1 swaybars? Thnx.
Old Mar 23, 2009 | 07:33 AM
AU N EGL's Avatar
AU N EGL
on all the C6s the ZR1 sway bars are not as stiff as the Z06 sway bars but closer to the Z51 if not the same as the Z51 sways, which may be the same as the front Z06 sways. There are all very close
all the sway bars are the same width.
If yor looking for something much different the GM T1 or the Pfaft sway bar set ups
Old Mar 23, 2009 | 08:58 AM
C5Natie's Avatar
C5Natie
Thnx. I will check those out as well. Just looking for a good handling upgrade without going to something too harsh or crazy.
To ZR-1 Suspension
