Rotors & Brake Pads
Old Mar 27, 2009 | 07:05 AM
vabadger's Avatar
vabadger
Default Rotors & Brake Pads
Hey Guys, If I had a hard time programming my VCR is there any chance in he**I can replace the brake pads and rotors myself? 1998C5
Old Mar 27, 2009 | 07:32 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That really deends on your mechanical abilities and whether or not you have the tools at your disposal to do the job.
Old Mar 27, 2009 | 09:28 AM
dougbfresh's Avatar
dougbfresh
Easier than a VCR, just need the tools.
Old Mar 27, 2009 | 10:10 AM
jrose7004's Avatar
jrose7004
Shouldn't be a problem.
Old Mar 27, 2009 | 11:01 AM
waddisme's Avatar
waddisme
I am an accountant and I do mine. Pads will be pretty easy. You just need a 15mm socket and a 16mm wrench and C-clamp or big pliers(to spread calipers). Now if you are changing rotors it gets a little harder. You have to remove the caliper brackets, which takes a 21 or 22 mm socket and a big breaker bar, as they are factory torqued at 125 plus age. For some reason, the rears always seem to be harder. I ended up having to take mine to a tire place to break rears loose as I couldn't get car up high enough to get a breaker bar on it. I have to do mine this weekend for a thurs track day. I may do a DIY write-up w/pics as there doesn't seem to be cf one. Once you do it, you will be glad you saved yourself the money.
To Rotors & Brake Pads
