Replacing Water Pump With LS3 Pump
Old Mar 28, 2009 | 06:48 PM
RanBurVette's Avatar
RanBurVette
Default Replacing Water Pump With LS3 Pump
I am installing a new A/C Compressor and will change the water pump
while am at it. Can't find a GM part number that will interchange a
1998 LS1 with a new LS3 pump including the thermostat housing and
thermostat. Any help would be appreciated. I am assuming the dive
belts are the same. THANKS
Old Mar 29, 2009 | 11:32 PM
RanBurVette
Default bump
ttt
Old Mar 30, 2009 | 05:21 PM
cwalsh's Avatar
cwalsh
Give the guys at SDPC a call. THey should be able to help or Gene at GMpartwarehouse.
Chris
Old Mar 30, 2009 | 08:33 PM
SanfordB's Avatar
SanfordB
What is the benefit of the LS3 pump over an ls1/6 or any other for that matter?
Old Mar 30, 2009 | 10:30 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I just put the pump kit, 89018053, on my 99. Includes pump, gaskets, thermostat w housing. I do'nt know if it is a LS-3, but it is the standard replacement for all C-5's.
To Replacing Water Pump With LS3 Pump
