Exhaust Question?
Old Mar 28, 2009 | 08:14 PM
NYVette01's Avatar
NYVette01
Default Exhaust Question?
I know this is very noobish but I need to know quick and I couldn't find anything in the search.
I have a 99 FRC and I want to eliminate the cats. What is the exhaust diameter on this car stock? Thanks!
Old Mar 28, 2009 | 08:22 PM
Oldvetter's Avatar
Oldvetter
OH OH, you know this is illegal and in violation of Federal Laws !
Seriously, your car will stink (literally) without cats.
Old Mar 28, 2009 | 08:25 PM
lucky131969's Avatar
lucky131969
2.5 inch. I say go for it.....cut those suckers out..
Old Mar 28, 2009 | 09:21 PM
a1231212's Avatar
a1231212
whos cares about being legal
Old Mar 29, 2009 | 04:49 PM
Oldvetter's Avatar
Oldvetter
Does NY have an emissions check? After removing your cats, you will get a "check engine light" and fail an emissions exhaust or computer check. It could be expensive for you to replace these cats.
Old Mar 29, 2009 | 06:01 PM
a1231212's Avatar
a1231212
true...how much do you know?
Old Mar 29, 2009 | 08:38 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Minnesota is still a cat-free state!
Old Mar 29, 2009 | 08:39 PM
happa's Avatar
happa
Cut them out. I did when I first got my vette. It was cheaper and sounds really good than buying new ones.
Old Mar 29, 2009 | 08:49 PM
a1231212's Avatar
a1231212
really??
Old Mar 29, 2009 | 08:59 PM
vetpet's Avatar
vetpet
Setting aside the legality of removing the cats and having to pass emissions tests what do you really think you'll gain by removing them? Why not replace the stock cats with a set of hi-flow ones? They flow well and have a neglible impact on performance, plus you'll pass emissions and won't have to put up with the stink of not having cats. There's no real benefit in totally removing your cats for a street use car and anyone that says different doesn't know what they're talking about......but if you want to learn the hard way, go ahead.
Old Mar 29, 2009 | 11:42 PM
ALLEGRO's Avatar
ALLEGRO
Here's my choice
Old Mar 30, 2009 | 12:18 AM
81c3's Avatar
81c3
Dont do it. It smells very rich and the popping on decel makes your high performance sports car sound like an old dump truck Seriously, the gains are not worth effort. I just this week, took off the set up you want in favor of headers, hi-flow cats and an x pipe.
Old Mar 30, 2009 | 10:23 AM
NYVette01's Avatar
NYVette01
Yes we do but I have ways to get inspected without all the "legal" parts. And the check engine light is a really easy fix with these cars.
But at the same time some of you reinforced my decision not to do it because why mess with the stock exhaust anyway when I am planning on replacing it anyway. No point.
Old Apr 30, 2009 | 06:11 PM
kettemr's Avatar
kettemr
what's the cost to replace the cats?
Old May 1, 2009 | 02:21 PM
a1231212's Avatar
a1231212
the piping isnt too much
Old May 1, 2009 | 02:34 PM
Indy's Avatar
Indy
The rear O2 sensors can be removed from the programming with a tune...then you're set for a cat-delete
Old May 2, 2009 | 04:45 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I cut the CATs off my stock 99 exhaust to sell em and the upstream piping was double walled. the inner pipe was 2.5" and the outer pipe was 2.75" I THINK, I didn't measure em but I was thinking it would be a PITA to just replace the CATs with this setup... You'd have to cut the outer wall back far enough to weld the inner pipe to the new exhaust. Not to mention the bend.
To Exhaust Question?
Old May 16, 2009 | 12:10 PM
titus40's Avatar
titus40
This might be a little bit of topic but since we are talking about eliminating components on the exhaust.
Do i need to lower the rear cradle to remove the stock exhaust system? I don't want to cut it and from the looks of it the piping wont be able to be pulled out without lower the rear cradle. Any input on this would be greatly appreciated. Thanks
Old May 16, 2009 | 02:26 PM
TurboBerserker's Avatar
TurboBerserker
NY does not "sniff" -- just a simple OBDII port check.
Obviously, it's very easy to pass this inspection without cats (hell, even without the rear o2s in the car...)
Old May 16, 2009 | 08:56 PM
a1231212's Avatar
a1231212
