Squeaking dammit!
Old Mar 28, 2009 | 09:39 PM
Torch FRC's Avatar
Torch FRC
Default Squeaking dammit!
At speeds below 25 mph I get a squeaking noise when driving (it sounds like brake squeal). It sounds like the left front. Before I start looking for the problem I would like to see if its a common issue and if someone could point me in the right direction. I went to a car show today and had to park in the back to avoid driving by everyone because it sounds that bad -Thanks
Old Mar 29, 2009 | 06:41 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
The pad wear indicators will cause the brake pads to squeak at low speeds. Check your pads for excessive wear, it may be time to replace them.
Old Mar 29, 2009 | 06:50 PM
Torch FRC's Avatar
Torch FRC
Pads are fairly new but thanks for the suggestion
Old Mar 29, 2009 | 08:44 PM
happa's Avatar
happa
Sometimes cheap pads will do that, I learned the hard way. Good Luck finding the problem
Old Mar 29, 2009 | 08:50 PM
carsangelop's Avatar
carsangelop
Does the sound go away when you step on the brake? Sure sounds like the wear indicators
To Squeaking dammit!
