fuel odor
Old Mar 29, 2009 | 07:43 AM
BosqueVette98's Avatar
BosqueVette98
Default fuel odor
I have a 98 A4. Lately I have noticed a fuel odor, pretty strong, after driving it. The only mods the car has is an x-pipe and cat back.
Any ideas what might be causing the fuel smell?
Thanks for any thoughts!
Rich
Old Mar 29, 2009 | 08:14 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Might be your fuel filter.
Old Mar 29, 2009 | 08:30 AM
KROHN27's Avatar
KROHN27
I had the same problem and my pass. side fuel tank had a crack in it at the top. It was literally spraying out fuel when the system would pressurize and I had a full tank. You might want to check it out could be pretty serious.
Tyler
Old Mar 29, 2009 | 08:55 AM
BosqueVette98
Thanks for the replies! Man, I hope it's only a fuel filter and not a cracked tank!
Old Mar 29, 2009 | 08:56 AM
BosqueVette98
Tyler
Is there an easy way to check this? Should I be seeing fuel on the garage floor if it was leaking from a cracked tank?
Old Mar 29, 2009 | 10:48 AM
Redhawg's Avatar
Redhawg
On my 98 it started with oder and then the leak. O-ring on filter was bad.
Old Mar 29, 2009 | 11:01 AM
BosqueVette98
thanks!
Is replacing the fuel filter an easy do-it-yourself fix?
Old Mar 30, 2009 | 09:25 AM
KROHN27's Avatar
KROHN27
It smelled like fuel really bad every time I would top off the tank and every time I got in the car it seemed like it had 1/8 of a tank less than the last time I drove it. I had my mechanic fix it but he said you could see leak when the car was on a lift. and he was poking around up there.
Old Mar 30, 2009 | 10:06 AM
Redhawg's Avatar
Redhawg
thanks!
Some say yes some say no. Use the search lots to read. Mine was easy went right in
Old Mar 30, 2009 | 06:30 PM
BosqueVette98
crawled under the car and looks llike the filter has been leaking... fixin' to go try to replace it... wish me luck...
well, got frustrated because i couldn't get the darn little plastic clips off the old filter didn't realize i had to remove my darn exhaust...
any tips? filter from Checker is $15, stealership charges $138...
Old Mar 30, 2009 | 09:49 PM
Z06rider's Avatar
Z06rider
Tyler
had the same issue as above...check it out.
Old Apr 6, 2009 | 08:42 AM
9secondflat's Avatar
9secondflat
where is the fuel filter located? does anyone have a pic from under the car? thanks
To fuel odor
