Solenoid ground
Old Mar 29, 2009 | 09:35 PM
bowtiebubba's Avatar
bowtiebubba
Default Solenoid ground
I am needing a ground for a purge relay & a ground for the purge solenoid on the passengers side of the car. Can i just ground them to the neg. battery post?
Old Mar 30, 2009 | 06:03 AM
bowtiebubba
ttt
Old Mar 30, 2009 | 03:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a battery cable to Chassis ground on top of the frame next to the battery. Its Chassis Ground stud G-104/108.
Find the negative battery cable and you will see that theres TWO wires on it. The small one goes to that ground point. Its a 10mm nut on a stud. Make sure that you soak it in PB Blaster before you wrench on it. Once its apart, clean the wire and chassis good and reassemble.
Old Mar 30, 2009 | 03:32 PM
hornet7's Avatar
hornet7
Default PB Blaster
Good Advise on soaking the nut first. Heard many times that the stud will break off. Not sure I know what PB Blaster is. So, will WD40 work?
Old Mar 30, 2009 | 04:10 PM
bowtiebubba
Thanks, i appreciate the help.
To Solenoid ground
