Drag Radial Help on Z06
Old Mar 30, 2009 | 11:46 AM
JKennedy1612's Avatar
JKennedy1612
Default Drag Radial Help on Z06
Anyone running this size on a stock Z06 rim without having rubbing issues?
http://www.mandhtires.com/store.php?...on=show_detail
Old Mar 30, 2009 | 12:30 PM
Drewstein's Avatar
Drewstein
I'm 90% sure that will rub. You'll need a 35 series sidewall if you want to avoid rubbing with that big of a tire me thinks.
Old Mar 30, 2009 | 01:39 PM
JKennedy1612
Hmm...anyone else?
Old Mar 30, 2009 | 05:58 PM
Eric04Z's Avatar
Eric04Z
WAY too big...35 series is the best. I run a 295 35 18 bfg drag radial wich has a 26.2 OD, im 100% sure you will rub, there is no reason for that size tire anyway unless your trying to snap a few things. Nitto nt555 has a 305 35 18 DR with a 26.4 OD which is also a perfect fit for the stock c5z 10.5" rim
To Drag Radial Help on Z06
