Headlight motor help?
Old Mar 30, 2009 | 06:29 PM
JJEXP's Avatar
JJEXP
Default Headlight motor help?
Hey guys, I've tried searching this one out, but now I'm at a loss. My left side headlight will not go up and down, while the right side functions fine. I have no power at the headlight motor/harness itself. I do have power at the fuse block under the hood. I've also disassembled the switch, but it appears there is only one contact to control both motors. I'm hoping someone here may have a further thought.
Old Mar 30, 2009 | 07:45 PM
byronhunter's Avatar
byronhunter
This should help: Two fuses, 1 left, 1 right.
Old Mar 30, 2009 | 07:51 PM
JJEXP's Avatar
JJEXP
That does help, thanks. Any idea as to where that module might be hiding?
Old Mar 30, 2009 | 08:15 PM
byronhunter
Just behind and below right hand headlamp.
Old Mar 30, 2009 | 08:17 PM
byronhunter
Did you check the 2 fuses with a meter, or switch them?
Old Mar 30, 2009 | 08:20 PM
JJEXP's Avatar
JJEXP
metered the sockets, switched the fuses, and metered the new ones.
To Headlight motor help?
