clutch problems
Old Jan 30, 2002 | 10:13 AM
4stroke's Avatar
4stroke
Default clutch problems
After my ZO6 gets around the track a few times the clutch pedal will occasionally stick to the floor and gear changes are very difficult. I can pull the pedal up and it may not do it again for several shifts them it's back to the floor. The clutch MC is full and there are no leaks that I can find. I now have to start it in gear to get into first and have to speed match the engine and trans to shift. Any ideas? Its now in the GM shop. Thanks for your input, Maury
Old Jan 30, 2002 | 10:24 AM
chuckster's Avatar
chuckster
Default Re: clutch problems (4stroke)
http://forums.corvetteforum.com/zerothread?id=214330
Old Feb 1, 2002 | 05:31 AM
levrac68's Avatar
levrac68
Be careful, sticking to the floor is exactly how my clutch helped me blow my transmission. Have the lines wrapped with a heat shield and if you can get out of the stock clutch setup. Good Luck. :cheers:
To clutch problems
