Injectors
Old Apr 2, 2009 | 07:15 PM
SearayC5's Avatar
SearayC5
Default Injectors
I will be running a TSP Torquer V.2 cam in 2003 Z. It will have ported and polished heads, underdrive, headers, vararam, etc. Should I upgrade the injectors to 30 lb SVO injectors? These will push 36 lb on the LS motor. I currently have the stock 28lb injectors. The injectors will be at 90 % duty with the 430 to the wheels.
Old Apr 2, 2009 | 07:33 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You will be running a cam...and already have hp #s to share?
Can you pick my lotto numbers for the Sat drawing please!! j/k
The stock injectors will likely exceed 100% IDC well below 430rwhp, so yes, the red top SVO's would be a wise purchase.
Old Apr 2, 2009 | 07:54 PM
SearayC5's Avatar
SearayC5
Lol I know Y2K. That is what Howard at Redline guesstimated. He suggested the 30 lb SVOs, so I just before I hit the "Buy" button, I wanted to get some input.
Old Apr 2, 2009 | 08:57 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
absolutely upgrade to 30lb injectors
Old Apr 2, 2009 | 09:01 PM
SearayC5's Avatar
SearayC5
Injectors purchased, but one more question. I was planning on driving to the tuning shop about an hour away after cam swap. Will I no longer be able to drive the car there with new 30 lb injectors?
Old Apr 3, 2009 | 11:18 AM
SearayC5's Avatar
SearayC5
Comments on the drive?
Old Apr 3, 2009 | 11:21 AM
roysvett's Avatar
roysvett
Default i have this combo
i have the torquer v s cam headers and put down 427hp 403tq and dont have any problems in fact i was running rich at idle and run the car at 12.2 afr on the dino to get those numbers the injectors run at 87% i know a little high but 10000 miles still no issues i also have a good starting point for this set up for hp tunner spent a lot time and money on this tune and no fancy aftermarket heads and a stock intake
Old Apr 3, 2009 | 11:52 AM
JJS04's Avatar
JJS04
Cruise-In X Veteran
I had 28# injectors in my head/cam, forged '99 and IPS Motorsports immediately said that they were way too small. They installed 42# injectors and re-tuned and the car runs fantastic. SVO 30# will also work great for you. My buddy has a '03 Z with head/cam and runs 30# SVO.
To Injectors
