Head Gasket Question
Old Apr 2, 2009 | 09:55 PM
geezel's Avatar
geezel
Default Head Gasket Question
I've just intalled MLS head gaskets on my 97 with 243 heads. Something's always been nagging at me - 97 FSM as well as LS1howto says gaskets are unique to each side (2 tabs one side 1 tab other). gmpartsdirect.com doesn't differentiate between the two sides, only one part number listed for head gaskets (97 or otherwise). I'd just feel better if I knew both heads are the same and that if I get the "front" positioned correctly I'm good to go.
Old Apr 2, 2009 | 10:13 PM
vettezeke's Avatar
vettezeke
Default Head gaskets
I believe that LS1tech and the FSM both reference the older graphite gaskets which had a left and a right. The MLS use the same gasket on both sides just flipped. I just did the same thing putting 243's on a 99, and as far as I could tell that is the story. If thats not right I got a problem as well. Hopefully someone else will answer.
Old Apr 3, 2009 | 05:36 AM
vettenuts's Avatar
vettenuts
Yes, they are just marked "Front". You can also verify the cooling hole alignment near the dowel pins. The rear is much larger than the front and the gasket should align.
Old Apr 3, 2009 | 09:53 AM
geezel's Avatar
geezel
That's what I thought. Thanks.
To Head Gasket Question
