Rumbling vibration at dead stop
Old Apr 3, 2009 | 12:39 AM
MyNavyBlue2001's Avatar
MyNavyBlue2001
Default Rumbling vibration at dead stop
I have 01 A4 that I just recently purchased. I've had it for 5 weeks now and I'm having a reoccurring rumbling vibration noise that only happens when I'm at a dead stop. Usually while waiting at a traffic light. When I start moving again the noise goes away. Yesterday, it happened again. I bumped it up to neutral and the noise went away. So, I'm assuming it's coming from the transmission or somewhere in the drivetrain. By reoccurring, it's happened about 4 or 5 times during 500 miles of driving. Has anyone had the same problem that I'm having? Thanks in advance.
Old Apr 3, 2009 | 07:11 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Make sure that both of the springs on the exhaust are in place. I take it is is an A4. Torque may have the pipes just barely touching something under there. I had a spring off and it made a rumbling sound.
Old Apr 3, 2009 | 07:16 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Check the exhaust system first. If not that you could have something going on with the propshaft. How many miles on this new to you Corvette?
Old Apr 3, 2009 | 09:51 AM
MyNavyBlue2001
I put on a catback exhaust system right after a bought it and the right side over the axle pipe rests up against the side of the transmission. I tried to pull it away but it won't move away enough to clear the transmission. It's one of those NXT Step Performance systems. Hopefully, it's just the exhaust system and not a transmission problem. It has 163,000 miles on it...mostly highway miles. The previous owner had it since it had 6,000 miles on it and took really good care of it. I knew by buying a Vette with this many miles, that I was looking at having some serious problems down the road. I got a pretty good deal on it and am prepared to tackle any problems that arise...to keep my dream of owning a Vette alive. I'll try to look under it this weekend and see what I can do about that pipe. Thanks for the suggestion.
Old Feb 8, 2010 | 10:39 PM
jbhesse's Avatar
jbhesse
Did you get this problem solved? Could be a motor or transmission mount causing the engine to shift an then the exhaust hits slightly someplace.
Old Feb 8, 2010 | 11:24 PM
NavyDoc2007's Avatar
NavyDoc2007
I've had this problem intermittently as well. I searched for it on the forum a few months ago and it seems to be fairly common. I haven't checked my exhaust yet as it doesn't happen all the time and if you raise the RPMs by a couple hundred or so with one foot on the brake, one on the gas, the noise stops. I think if it was something serious it would happen all the time. Let us know what you find out. If I ever have time in the near future, I plan on putting mine up in the air and checking the exhaust.
Tim
Old Feb 9, 2010 | 02:09 PM
RSchleder's Avatar
RSchleder
I bought my 2000 vert in 2004 and it's done it since day one. I even changed the alt and pully tensioner and that didn't fix it. I also changed exhaust system to a Corsa PC and their X pipe. Guess what- it's STILL there. This is not an uncommon sound/noise in these cars. My recommendation, live with it (turn the radio up if you must)
Old Feb 9, 2010 | 02:17 PM
lucky131969's Avatar
lucky131969
Not sure what's more strange.....changing a pulley for a driveline vibration, or suggesting that the OP live with it......when he could have a serious problem......
Old Feb 10, 2010 | 05:07 PM
RSchleder's Avatar
RSchleder
Lucky131969- here's a news flash for you. There is a GM Service Bulletin for a "drivetrain rumble" at idle and it is to CHANGE the Alt. on cars prior to 2001 to the alt.(found on 2001 and later cars) with the black nose (clutch) type.. The SB also states to change the belt tensioner. This action was also recommended by an very experienced Master GM certified technician on another very popular Corvette forum. So, my recommendation was not pulled out of my dark place, it was given based on GM Service Bulletin information and a recommendation from a very experienced technician. NOW "you know the rest of the story"
Old Feb 10, 2010 | 05:30 PM
lucky131969
Hmmm......"drivetrain rumble", huh? No chance you could be confusing things with TSB 99-06-04-029A, which is for "Accessory Drive Rumble"? Here's the interesting coincidence: the repair for the accessory drive rumble, was to replace the alternator, and tensioner pulley.
So you have some sort of vibration under your car (which obviously still exists...possibly drivetrain..who knows) and a "GM Master certified tech" told you there was a service bulletin for this issue...and at the end of the day....your problem remains after you followed his advice. So much for the "very experienced Master tech"........
How's that for a news flash.......
Old Feb 11, 2010 | 08:15 AM
RSchleder's Avatar
RSchleder
Lucky- you are correct "Accessory drive rumble" was the SB I was taking action on. I misspoke, thanks for the "correct news flash". Ron
Old Feb 11, 2010 | 08:39 AM
CurbsEnthusiasm's Avatar
CurbsEnthusiasm
It appears to be very common with A4 vettes, it happens to mine once in a while at a stop light, generally I notice it after coming to a harder/quicker stop then just coasting down. I believe that its the torque converter, simply throwing it in neutral and back into drive corrects the problem.
Old Feb 11, 2010 | 09:03 AM
rebelheart's Avatar
rebelheart
I think if you find out why your exhaust is hitting your transmission your problem will be solved,a good place to start at least!
Old Feb 11, 2010 | 05:39 PM
cvm's Avatar
cvm
Old Feb 11, 2010 | 09:20 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Old Feb 12, 2010 | 12:08 AM
Choreo's Avatar
Choreo
Does your RPM and or voltage drop when this happens? If so, I found my problem after several months of this at traffic lights - it was a small amount of gunk in the throttle body causing the butterfly to stick momentarily at idle when in gear. Car felt like the crank was going to drop out of the engine until I would shift to neutral. I am guessing this buildup was from using an oiled air filter with too much oil (or just the tradeoff over time)?
Old Jun 18, 2010 | 03:35 PM
Texas Dave's Avatar
Texas Dave
I'm wondering if the OP ever found anything, as mine does the exact same thing.
To Rumbling vibration at dead stop
Old Jun 18, 2010 | 05:46 PM
FLYNAVY30's Avatar
FLYNAVY30
My 2003 Z06 (manual obviously) has the same rumble when you first start it up and occasionally at stop lights...It started only after I had installed Long Tube headers/Cats/X pipe. After the car warms up, it goes away. Ive looked high and low and I cant find any place where anything is rubbing but Im assuming something with the exhuast is just barely tapping something. Its been doing it now for the better part of 3 years with no damage to anything...Ive learned to live with it but I know many people expect Mercedes levels of refinement from their American sports car. I figure with the amount my car shakes due to the big ole cam, some things are bound to squeak...personally I like it!! Gives the car personality
Old Jun 18, 2010 | 11:20 PM
ShootCraps's Avatar
ShootCraps
I've been working on this problem with my 2000. The oem balancer was going bad so I replaced it and expected the noise to stop but it didn't. It was reduced, but not gone. I also replaced the tensioner but that didn't help.
I bought a Katech manual tensioner but that made the problem worse. Then I watched while someone put the car in drive and the serpentine belt bounced like crazy coming off the alternator pulley while making the noise. Based on this thread I may try replacing the alternator.
To isolate the pulley system, take the serpentine belt off and start it. You can run it for a couple minutes without the belt, just watch the temp. When I did that on mine, the noise was completely gone.
Old Jun 19, 2010 | 10:45 AM
CurbsEnthusiasm
I have quite a few friends on the Fbody side of the world and they all (with A4's) mention there is a known solenoid issue with the torque converter which causes this vibration.
