Just dropped my '99 off at the stealership for them to flush the brake fluid and do a four wheel alignment. The car only has 39,000 miles but the fluid was absolutely filthy. The car also has upgraded brakes so the fluid can't be any more than 25,000 miles old.
The color of the fluid is not a conclusive evaluation of it's condition. Your motor oil goes in golden brown, but turns dark well before a change is required as well.
Good point. Never thought of that. But it is going to make me feel better knowing that it is new.
It really depends how you drive the car. I would suspect that most people never have their brake system flushed for the life of the car (grocery getter, etc). If you demand top performance from you car at all times, then changing the brake fluid on a regular basis ensures it will perform to your expectations.
It's more a matter of time than miles. brake fluid will absorb moisture over time so I am a believer in getting the fluid completely flushed every 5 years or so, regardless of mileage.
Disclaimer: I don't race and there are smarter guys than me on this forum.
Here's how I handle brake fluid flush. I always use synthetic because I read once that it didn't tend to absorb as much moisture over time. I use a garden sprayer and put in a quart or so of brake fluid. Then connect the sprayer hose to a spare master cylinder fluid cap by drilling out the vent hole and inserting a brass nipple. Pressure up the sprayer a little, open up the bleed valve on the right rear wheel, let it drain. Next LR then RF and LF wheels - the idea is get the long brakelines in the back done first, then the front.
If I'm doing something stupid, please correct me so at least others don't mess up their fine rigs.
I usually keep my cars about 10 years and 110,000 miles and have never flushed brake fluid, UNTIL. . . I replaced rotors and pads at about 115,000 miles on my C5, figured might as well flush them. BTW, this was the 3rd set of pads (counting originals). Took the second set (GM Ceramics) off early as I was not happy with them.
