HUD problem
Old Apr 3, 2009 | 05:48 PM
dmoore's Avatar
dmoore
Default HUD problem
Jumped in the car today and noticed only a portion of my HUD was working. I can see the speed and tach but the portion where you can see gas gauge does not appear. I tried the page button several times but nothing helps. Any suggestions?
Old Apr 3, 2009 | 10:18 PM
CARRJET's Avatar
CARRJET
Hi,was you sitting still? maybe sunlight reflecting, any debris in HUD screen?
Old Apr 3, 2009 | 11:22 PM
dmoore's Avatar
dmoore
Checked all that! Sitting still and driving can't see it.
Old Apr 5, 2009 | 12:45 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
This one might be pretty easy. Let's see... If you battery is starting to lose its mojo, all sorts of strange things can start happening.
But try this...
The page button works in two different ways. If you press and release quickly, it will scroll through the screens one way. But if you hold and continue to keep it down, it will scroll through the visual options in a different way. One of these will remove the gas level while keeping the tach and speed. Try it.
Old Apr 5, 2009 | 11:28 AM
DeeGee's Avatar
DeeGee
Originally Posted by JMc
This one might be pretty easy. Let's see... If you battery is starting to lose it's mojo, all sorts of strange things can start happening.
But try this...
Just what I was thinking
There are five HUD selections that you can choose to
view in the HUD display. By pressing and holding the
PAGE button, you can scroll through these pages in
the following order:
Speed Only
Speed and Gage
Speed, Tachometer and Gage
Speed and Tachometer
Tachometer Only
When you have chosen the desired HUD display,
release the PAGE button.
Gages can be scrolled through by tapping the
PAGE button (only when a gage is displayed).
The gages shown are the following:
Oil Pressure
Coolant Temperature
Fuel Level
The selections that you choose will remain in the
HUD display until they are changed.
Old Apr 5, 2009 | 04:34 PM
CARRJET's Avatar
CARRJET
this is more difficult, I was reading my service manual and troubleshooting tree stated to jumper puple wire to ground, I'm assiming the dash pad has to be removed to get to the HUD to IPC harness where this wire is. if the HUD segments all light up it could be an IPC problem or shorted wire, hopefully someone else can help
Old Apr 5, 2009 | 05:18 PM
JMc's Avatar
JMc
I'm pretty sure that someone else has! See posts #4 and #5 above.
Old Apr 6, 2009 | 12:26 AM
dmoore's Avatar
dmoore
Thanks to everyone for help! Its working again. I held the page button down and got everything back! The car had to be in neutral and emergency brake on for it to toggle through.
Old Apr 9, 2009 | 07:12 AM
SpeedUp's Avatar
SpeedUp
love this site
To HUD problem
