Test Injectors
Old Apr 3, 2009 | 08:26 PM
mjparrie's Avatar
mjparrie
Default Test Injectors
Is there a way to test my injectors? I have one making alot of noise and my car is sluggish.............no codes. 98
Old Apr 3, 2009 | 10:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Send them off and have them cleaned, tested and flow tested.
BC
Old Apr 4, 2009 | 07:16 AM
dougbfresh's Avatar
dougbfresh
There are only a couple of easy tests in car, ohm test on the coil (seem to recall most GM injectors are in the 10-14 ohm range) and fuel pressure test to see if they close on shutdown of car (fuel rail should hold pressure for some time after turning off the car). You can also use a mechanics stehescope to listen to each injector.
You can get an injector pulser off of fleabay that allows you to single or triple pulse a single injector. re you sure it's an injector making the noise?
Old Apr 4, 2009 | 08:18 AM
sami85L98's Avatar
sami85L98
BC
Send them off to neweraperformanceparts.com and they are our supporting vendors too, they r located in NY.
To Test Injectors
