Reverse Lights not working??
Old Jan 30, 2002 | 02:47 PM
Phil97SVT's Avatar
Phil97SVT
Default Reverse Lights not working??
I just noticed my reverse lights dont work when I put my corvette into reverse but they do light up when you hit unlock on the key fob so I know they work. What is the easiest way to diagnose the problem and see what needs to be replaced? Someone said it was the reverse switch on the rear end/tranny. :confused:
Old Jan 30, 2002 | 08:43 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Reverse Lights not working?? (Phil97SVT)
Replace the backup lamp switch on the right side of the tranny,common problem :yesnod: If you jump the 2 wires at the connector and the lights come on with the key on,its the switch :yesnod:
Old Jan 31, 2002 | 12:11 PM
mikecoffin1's Avatar
mikecoffin1
Just had mine fixed last week. Same thing...bright lights with key fob, nothing in reverse. GM...under warranty...replaced the switch at tranny. Honestly, I don't EVER remember mine working! Thought I was going blind for nighttime backups!!!
Old Jan 31, 2002 | 04:56 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Reverse Lights not working?? (mikecoffin1)
DITO
My switch went bad too. EASY FIX!!! Took about 20 min. That included driving up and off of the lift! :D
Bill Curlee
To Reverse Lights not working??
