Water Pump Gaskets
Old Apr 4, 2009 | 05:31 PM
geezel's Avatar
geezel
Default Water Pump Gaskets
The old gaskets were 1/16" thick aluminum with sealant around the ports (probably aftermarket as the water pump has been replaced). The new GM gaskets I bought were typical thin gasket material. Why the different types? Which is better?
Old Apr 4, 2009 | 08:53 PM
vettenuts's Avatar
vettenuts
All the GM gaskets I have bought were metal with a rubber seal attached. Are you sure they are the correct part?
Old Apr 4, 2009 | 09:16 PM
geezel's Avatar
geezel
The ones that came off were like the one in your pic. I guess they gave me the wrong part. Where they different by year?
Old Apr 5, 2009 | 03:08 AM
LoneStarFRC's Avatar
LoneStarFRC
Only the '97s and '98s had the thin paper or composite type gasket. Beginning in '99 all C5s have the silicone gaskets on an "aluminum carrier". The later versions work on all LSx and AFAIK, the old paper type is no longer offered by GM.
Old Apr 5, 2009 | 12:18 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Yes, you were given the 97 and 98 style. The newer ones are like the pictured.
Old Apr 5, 2009 | 03:11 PM
vettenuts's Avatar
vettenuts
I got those from Gene by the way.
Old Apr 5, 2009 | 05:21 PM
clemsondave's Avatar
clemsondave
I have one of the water pump gaskets picture above brand new in wrapper. It was left over from my truck motor rebuild. I ordered it from Gene, but I also got one in the box with the new water pump. You are welcome to have it, just PM me and I'll send it to you. Or, give Gene a call. Part #: 12610311
Old Apr 5, 2009 | 06:27 PM
TEXHAWK0's Avatar
TEXHAWK0
I have not had to replace a water pump yet. Is there a left and right gasket, or are the ports all on one side? If there are two gaskets, are they the same?
Old Apr 5, 2009 | 06:41 PM
vsocks1's Avatar
vsocks1
Gaskets are the same I have been told!
Old Apr 5, 2009 | 06:50 PM
LoneStarFRC
They are identical.
Old Apr 5, 2009 | 06:55 PM
clemsondave
Old Apr 5, 2009 | 10:27 PM
geezel's Avatar
geezel
...You are welcome to have it, just PM me and I'll send it to you. Or, give Gene a call. Part #: 12610311
Thanks for the generous offer, but I think I'll just pick up a pair tomorrow.
To Water Pump Gaskets
