Help my car will not start sometimes.
Old Apr 5, 2009 | 09:01 AM
4deatr's Avatar
4deatr
Default Help my car will not start sometimes.
Help my car will not start sometimes. Two weeks ago I put a new red top battery in my 2001 when it would not start. It car started every day for two weeks I went to get in sat and nothing. I got out my jump box and it started right up. I took it to advance auto and had the battery starter and the alternator it all tested fine. I don’t know what else to look for my car is my D/D and now I will have to drive around with the jump box in the trunk. Any help you can give would be great.
Old Apr 5, 2009 | 09:18 AM
LightFighter_GXP's Avatar
LightFighter_GXP
something is killing your battery......... you need to find out what!! I would say that something did not check out fine if your battery is dead after a few hours.
how long does it sit before it won't start??
Old Apr 5, 2009 | 09:33 AM
4deatr's Avatar
4deatr
I drove it for two weeks every day and no problems. It started right up Sat am then I wash it and went to drive it and it was dead.
Old Apr 5, 2009 | 11:46 AM
bluvette79's Avatar
bluvette79
battery connections clean and tight? do you have guages when this happens and does the starter turn but car not starting?
Old Apr 5, 2009 | 01:26 PM
4deatr's Avatar
4deatr
Yea its a new battery and the connections clean and tight. The starter turns over the car just will not start. As soon as I jump it its fine and the car has started 3 times today no problem.
Old Apr 5, 2009 | 03:19 PM
bluvette79's Avatar
bluvette79
it would seem to me that if it starts from a jump it has to be battery or connections. and if it turns over either way, there is no electrical difference other than the jump providing more current to the starter. is the battery ground connection good on the car side (ie chassis ground) for the battery? it has to be the battery, connection or ground. someone chime in if bad connection at coil pack would be involved but it would not be different with a jump. the jump bypasses the battery ground and thus my reasoning
Old Apr 5, 2009 | 03:27 PM
lucky131969's Avatar
lucky131969
Ok, let's take a step back here. What you need to know is, the condition of the battery when it does not want to start. Like already stated by LightFighter_GXP, you may have something bringing the battery down....especially because it jump starts ok. I would audit the current draw with a DMM.
Old Apr 5, 2009 | 10:54 PM
4deatr's Avatar
4deatr
chassis ground where is it?
Old Apr 6, 2009 | 09:20 AM
bluvette79's Avatar
bluvette79
i'll look it up when i get back home but you might just be able to follow the negative battery cable. anybody else tell him in the mean time?
Old Apr 6, 2009 | 11:54 AM
lucky131969
Are you joking, or do you really not know what a chassis ground is?
Old Apr 6, 2009 | 02:04 PM
bluvette79's Avatar
bluvette79
i think he was asking where not what.
check out this thread from bill curlee. it talks about ground problems and ground locations. i still think you need to follow the battery ground cable.
http://forums.corvetteforum.com/c5-t...tml?forum_id=1
Old Apr 6, 2009 | 05:49 PM
4deatr's Avatar
4deatr
I Know what it is I was asking where it was.
Old Apr 6, 2009 | 05:50 PM
4deatr's Avatar
4deatr
Thanks that gave a lot of good info.
Old Apr 22, 2009 | 02:03 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Marty, send me a plain ticket, I will work for that alone!
To Help my car will not start sometimes.
