Pull key wait 10 seconds
Old Apr 5, 2009 | 07:08 PM
Magred6sp's Avatar
Magred6sp
Default Pull key wait 10 seconds
Hey guys, I keep getting the pull key wait 10 seconds message after the car sits for 1 to 2 weeks. If I do what it says, it works fine no problems until the next week after it sits. I have a 2001 M6 coupe. Unfortunately all the GM fixes for the Column lock have been done. I purchased the car from a GM dealership in Oct 2007. The car only has 26000 miles. I saw a thread a month or so back from Bill Curlee that gave directions on how to check the key pellet and then the "can" that reads the key pellet. I pulled everything apart today, and it all checks out fine. Any ideas? Am I getting warnings of the CLB issue? Any help would be appreciated.........................Than ks, Dave
Old Apr 5, 2009 | 10:19 PM
itzza427's Avatar
itzza427
That is VERY similar to how it started for me. Cleaned the pellets ,checked the battery,,,still got the 10 second message on random occasions. Was not all that concerned( I did have a CLB,but had not installed yet),,after all it had been in for two recall fixes,,and the wheel turned when key was out. Well it got me anyhow,, THE FUEL CUTOFF that was programmed in during one of the recalls kicked in when the K-harness failed!!! I HIGHLY recommend removing the K-harness and installing a CLB!!!
Old Apr 6, 2009 | 02:50 PM
Magred6sp's Avatar
Magred6sp
Thanks for the responses. I'll order my CLB today. 8VETTE7, I have a brand new battery (3 months old) and I have it connected to a Battery Tender, do you think I could still have a battery problem? It's just a standard battery, Exide I think, nothing special.
I'll do the CLB and post the results............................Dave
Old Apr 6, 2009 | 05:10 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
I highly doubt its your battery....I WOULD install a CLB, but I dont think your issue has anything to do with column lock.
Here's some reading for you:
http://forums.corvetteforum.com/c5-t...ross-eyed.html
I started this thread way back...and with every's input, I STILL get this message every single day....I am convinced the only "fix" is trading the car in for a C6....
Old Apr 6, 2009 | 11:01 PM
aleadfoot's Avatar
aleadfoot
This happens to me when I leave the keys in the ignition and some how screw up the security sequence. Might be you and not the car Trying to help I might not be the only dumb one out here. If right it is the easiest fix. best of Luck
Old Apr 6, 2009 | 11:19 PM
Magred6sp's Avatar
Magred6sp
8VETTE7 I will test the voltage next time I get the message. I'm buried in snow again here, so won't be driving for a while. Ordered the CLB from CoH today. I will install it and watch what happens. Thanks for all the help.
SEE3ER - I read your thread.....very frustrating! When you had the ignition switch out did you test the voltage with the key in and out like Bill Curlee recommended? I did this and it tested exactly the same as the key pellet. Incidentally, my key is also a #15 (11.74kv) resistance. Wonder what key #'s others have with the Pull Key issue?
If anyone reads this chime in.....maybe it has to do the this key resistance? Who know..........Dave
Old Apr 6, 2009 | 11:26 PM
Magred6sp's Avatar
Magred6sp
aleadfoot - I thought the same thing at first. So I have intentially made sure I was insterting the key carefully and not being clumsy. I always wait for the gauges to sweep before I turn the ignition over.
Still get the message intermittently...........Oh well CLB is my next step.
Old Apr 7, 2009 | 07:14 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
I have no idea what you are talking about?????
Old Apr 7, 2009 | 07:18 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
I have tested all voltages, tested all resistances etc. My key is a #7--1.870 ohms, which I replaced the key reader with a 1.8 ohm resistor. Did nothing, and I put everything back to where it was.
Forgive my negativity....I've run out of patience
Old Apr 7, 2009 | 06:35 PM
Magred6sp's Avatar
Magred6sp
Sorry SEE3ER I read your resistance as 11.8 not 1.8. I thought I was onto something if we were both having problems with the same resistance keys. I guess I was just trying too hard.......Don't worry about the negativity, electrical issues can put anyone on tilt. Hang in there, the prices on C6 Z06's are coming way down .
Old Apr 7, 2009 | 06:43 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
WSell...now maybe you ARE on to something....maybe..just maybe I read it as 1.8, and its SUPPOSE to be 11.8 !!!!
Time for the ohm meter AGAIN!
Old Apr 7, 2009 | 09:59 PM
ICUALL's Avatar
ICUALL
Default VATS Bypass
There are 4 very small contact wires in the switch that "read" the pellet. Look just like "Cats Whiskers" I have seen where one of the 4 wires breaks off or is so bent out of position that it does not make contact. If you remove the key and reinsert it sometimes works fine. Very intermittent until the other contact wire breaks then it quits working completely. Then it is new ignition switch time or do the VATS bypass...
http://www.c5help.com/bypass_vat.htm for details on the bypass with pics....
Old Apr 7, 2009 | 10:07 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Interesting, I've had mine all apart--only 2 wires in mine....my issue is CONSISTENT...consistently never works first time, but consistently works every time I pull and wait...
PS: I've had the resistor soldered in and made no difference.
Old Apr 8, 2009 | 09:23 AM
Blu's Avatar
Blu
Mine did this 3 times before the column locked up. Luckily by jerking it side to side I got it to release and I didn't drive it again until I got the CLB mod. Got it, installed in about 15 mins and it hasn't done it since.
Old Apr 8, 2009 | 10:13 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
next up is fuel cutoff at 2mph
Old Apr 9, 2009 | 10:56 AM
Magred6sp's Avatar
Magred6sp
Waiting on the CLB. I will install and keep you all posted..............Dave
Old Apr 9, 2009 | 01:36 PM
poolboy's Avatar
poolboy
On the early year cars the CLB could actually cause pull key messages, but like your problem - If you pulled the key and then tried again, it worked fine. The only suggestions I would have is to make sure your grounds are all clean and tight, and I know some people have installed additional wires between the battery and some ground points to ensure a good ground circuit - I wonder if that would help pull key messages too.
To Pull key wait 10 seconds
