Wire Connection for 12 disc changer
Old Apr 5, 2009 | 07:11 PM
3whit's Avatar
3whit
Default Wire Connection for 12 disc changer
Ok I mounted the changer with great success , I have run the wire to the foot well fuze box , I can not find the plug in for it .My car is a 01 . I looked pretty thoroughly and cant seem to find it . Any hint as to where it is hidden . Any help will be appreciated.
Old Apr 5, 2009 | 07:41 PM
Patches's Avatar
Patches
Here's a link to my install - there's a pic of the connectors showing how they come out from around the right side of my fuse box.
http://forums.corvetteforum.com/c5-g...tml?highlight=
Old Apr 5, 2009 | 07:42 PM
byronhunter's Avatar
byronhunter
C204 is one of the connectors, #17
Patches beat me to it with some good info!
Old Apr 5, 2009 | 08:37 PM
3whit's Avatar
3whit
Is there two connectors ,I can only find the one with 4 pins . My connecting cable is one male connector measures about 1/4X1 inch .I think GM gave me the wrong Harness ,Could that be ,it plugs int the player perfectly ????????
Old Apr 5, 2009 | 08:41 PM
3whit's Avatar
3whit
Thanks Patches , I have looked and looked I can only find one four pin connector. The end on the harness I have is all in a row (male ) 1/4X1 inch .I think gm May have sold me the wrong harness. I still cant find the other plug by the fuze box , if there are two .Thanks for your help .
Old Apr 5, 2009 | 09:30 PM
byronhunter
There are 2 connectors, looks like both should plug into 1 connector on the cable to the rear. HTH
BH
Old Apr 5, 2009 | 10:05 PM
3whit's Avatar
3whit
Just ordered the correct harness ,still haven't found that other connector ,but its there some place .Thanks for the input .
Old Apr 6, 2009 | 04:09 AM
fdxpilot's Avatar
fdxpilot
You found the 4 pin connector, probably right next to the fuse box. I found my 3 pin connector under the carpet closer to the pass seat. It was hidden under carpet and padding.
Old Apr 6, 2009 | 06:31 AM
3whit's Avatar
3whit
Thanks I will do some diggin ,I know its there and everyone has said its a bear to find. Thanks for your reply.Rick
Old Apr 6, 2009 | 06:37 PM
3whit's Avatar
3whit
Found it ,Looked today after work and it was right in front of my face ,What a difference a day makes .
To Wire Connection for 12 disc changer
