New gears = cracked diff
Old Apr 8, 2009 | 10:06 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by k-mart
Still no word from the shop and I need this ASAP because I plan on driving it to the Grand Rod Runs in Pigeon Forge, TN. Hurry up guys!
thats coz they havent decided on what story to use....Do you honestly think the shop will admit fault and eat up the costs?
Old Apr 8, 2009 | 10:08 AM
lucky131969's Avatar
lucky131969
Originally Posted by Blu
My case just cracked as well at the track, but it was do to the tranny output shaft snapping causing a nasty chain reaction.
I bet the sequence of events was opposite, differential case cracked, and took out the trans.
Old Apr 8, 2009 | 10:16 AM
chriswtx's Avatar
chriswtx
maybe your friend couldn't resist a little squirt on the throttle and got some wheel hop.. wheel hop can crack the diff case...seen it on stock cars
Old Apr 8, 2009 | 10:24 AM
Blu's Avatar
Blu
Well the builder of the transmission was in agreement with the builder of the diff that the broken tranny shaft was my link to all the breakage.
http://forums.corvetteforum.com/perf...expecting.html
I believe they are correct in my case. Same thing happened to a buddy of mine on the same day at the track, he broke his main shaft but his diff survived only damaging the ring and pinion.
Old Apr 8, 2009 | 10:25 AM
Blu's Avatar
Blu
Originally Posted by chaase
when you get everything built back up, get the trans brace. It is there to prevent that chain reaction.
had one if you are referring to the DTE brace. I lost the driveshaft, cracked the bell housing, broke the trans main shaft and lost the diff case all in one pop.
The car has a built stage 3 diff, built trans with stock main shaft, DTE brace and stock torque tube.
Old Apr 8, 2009 | 10:46 AM
lucky131969
Yeah, those pics really help. Based on the way the output shaft is galled (and the direction), I still think the case failed first, and took out the trans.
Sorry for your misfortune.
Old Apr 8, 2009 | 11:06 AM
Blu's Avatar
Blu
So what about Kurtomacs and Chris Stewarts which both broke at the same angle, same location and their cases survived just fine?
Old Apr 8, 2009 | 11:07 AM
Kurtomac's Avatar
Kurtomac
my cracked ring gear tooth cause my trans output shaft to snap dope....jeeze blu get with the picture
Old Apr 8, 2009 | 11:25 AM
Kurtomac's Avatar
Kurtomac
hi blu!
Old Apr 8, 2009 | 11:30 AM
lucky131969
Just a hypothesis on my part. Looking at Kurtomacs pics, while the trans shaft failed, it clearly snapped...unlike yours.
If you feel confident that the trans took out your differential, that's all that really matters...after all...it's your car...and more importantly....your money.
Old Apr 8, 2009 | 01:53 PM
Blu's Avatar
Blu
Ok how did mine break then since you seem like you were there and had cameras in my drive train. You also seem to act like you know more about the situation than the builders and reps of RPM and Tick Performance.
