New Air Intake (pics)
Old Apr 6, 2009 | 03:26 PM
Slick Rick's Avatar
Slick Rick
Default New Air Intake (pics)
Well I didnt get 100 more HP but it looks cool. Hell it only cost 29.95 off flea-bay.
Old Apr 6, 2009 | 03:42 PM
95BlueBomber's Avatar
95BlueBomber
Yep I have had experience with this one too! I don't think you will be disappointed.
Just a quick question... What year is your car? I see that bracket on the back of the alternator, I dont remember seeing that one before.
Old Apr 6, 2009 | 03:55 PM
lucky131969's Avatar
lucky131969
Listed in the OP's sig as a 97. You know it's a 97 or 98 by the fuel lines.
Old Apr 6, 2009 | 04:55 PM
tony car4a's Avatar
tony car4a
It does look cool. Does it feel any different?
Old Apr 6, 2009 | 05:01 PM
chaase's Avatar
chaase
St. Jude Donor '12
looks good...now open up the fog light screen area and feed it some fresh air.
Old Apr 6, 2009 | 05:31 PM
Slick Rick's Avatar
Slick Rick
Nope, It might work a little better if I drill some holes around my foglight covers
Old Apr 6, 2009 | 05:36 PM
jrose7004's Avatar
jrose7004
I always liked the way those looked when I had one on my car too!
Old Apr 6, 2009 | 06:56 PM
c5blkvetteguy's Avatar
c5blkvetteguy
pm sent.
Old Apr 6, 2009 | 10:58 PM
aleadfoot's Avatar
aleadfoot
Now get a big *** airbridge and lose the accordian so your engine can breathe. Looks clean
Old Apr 6, 2009 | 11:15 PM
happa's Avatar
happa
That will help some too
Old Apr 7, 2009 | 10:26 AM
WalterSobchak's Avatar
WalterSobchak
Or the extra Alternator Bracket.
Looks sweet! Hopefully it sounds awsome!
Old Apr 7, 2009 | 10:37 AM
Sinister-one's Avatar
Sinister-one
Would this work better than a vararam ??
Old Apr 7, 2009 | 10:47 AM
Slick Rick's Avatar
Slick Rick
I wouldnt think so. The vararam is directly cold air fed through the foglight covers.
Old Apr 7, 2009 | 11:00 AM
Sinister-one
So does this CAI system draw "hot" air from the engine compartment as well ?
Old Apr 7, 2009 | 08:49 PM
FASST LN's Avatar
FASST LN
The thing is, after about 2 seconds of going WOT, you're going to suck all of the hot air out of the engine bay. After that, you'll be pulling in cooler ambient air...though it might get pulled in only after drifting by the hot engine.
I would really like to see someone post a decent test of intake air temperatures with a vararam and without. I would be surprised to see more than a 15-20 degree difference (though that is significant).
Old Apr 7, 2009 | 09:19 PM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
Not bad looking for fleabay.
Old Apr 8, 2009 | 10:23 AM
fixvet's Avatar
fixvet
Only the 1997 model year has the rear alternator bracket!
To New Air Intake (pics)
Old Apr 8, 2009 | 10:34 AM
C5Natie's Avatar
C5Natie
I just cut a hole on the air dam shroud under my CAI filter so as I drive the filter and engine bay are constantly fed outside air. This also reduces the "vacuum" effect our cars have and reduces the trash that gets stuck in there. I just cut the hole as close to the filter shape as I could so the radiator still gets plenty of cool air as well. Try cutting two holes, one under each filter. It will help.
Old Apr 8, 2009 | 10:42 AM
JCamaro's Avatar
JCamaro
Looks good......and anything would be better than the stock asthmatic breather box...
Old Apr 8, 2009 | 01:38 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I have a 2000 coupe with the same CAI as pictured and just bought the Vararam Air Bridge. It has the smooth couplers front and rear and moves the MAF to the rear (I guess it would be the front depending on how you are looking at the bridge) of the bridge closer to the intake manifold and throttle body. Question is has anyone else used this bridge with the CAI dual cone as pictured and would now be the time to replace the MAF stock 75mm with a larger MAF say the C5 Z06? Or given the rest of the engine is a stock 2000 LS1 would the larger MAF gain me anything? Does the Vararam Bridge gain me anything as well by itself? Thanks in advance for any info.
Bill
