Driver's side power lock not locking
Old Apr 6, 2009 | 05:11 PM
GFCmgb71's Avatar
GFCmgb71
Default Driver's side power lock not locking
Hey guys I picked up my 02 coupe on Friday of last week (awesome car btw ). I just noticed that the drivers side power door lock will unlock via the key fob or the button on the door but will not lock. I was wondering if anyone else has had this problem. I found a power door lock actuator and motor for the C5 for pretty cheap on a certain auction website but want to investigate more. I'd appreciate any feedback, Thanks in advance!
Old Apr 6, 2009 | 07:21 PM
vett79's Avatar
vett79
I have the same problem on my '98......I just reach over and manually lock the pass door. Too lazy to fix it
Old Apr 6, 2009 | 07:28 PM
Bakersfield's Avatar
Bakersfield
Guys, please don't be offended, but learn to use the search function. This is a common problem and has been addressed many times. I even wrote up a "How to fix it" on this very subject. Here is the link. Good luck!
http://forums.corvetteforum.com/c5-g...w-problem.html
Old Apr 6, 2009 | 08:02 PM
GFCmgb71's Avatar
GFCmgb71
No offense. I'll make note of that and thanks again for the info
Old Apr 6, 2009 | 08:42 PM
kcbeagle's Avatar
kcbeagle
I used this fix on my passenger door that would not unlock. Worked great and was CHEAP!! I spent about 12 bucks with shipping for 4 relays (wanted spares). This forum is great!
Old Apr 7, 2009 | 12:52 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I bought 4 relays, did the fix, and it still doesn't work. So I assume the switch is bad but I had that apart and cleaned the membrane and the strips on the board and it didn't work either. If I jam the lock button a few times hard it will sometimes lock. I just use the fob and live with it.
Old Sep 12, 2024 | 07:43 PM
rementis's Avatar
rementis
I get this error when trying to see Bakerfield's instructions:rementis, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Old Sep 13, 2024 | 01:31 PM
Dads2kconvertible's Avatar
Dads2kconvertible
https://www.corvetteforum.com/forums...post1607752001
Old Sep 14, 2024 | 01:39 PM
Moved to C5 Tech for further discussion.
Old Sep 20, 2024 | 10:57 AM
BRKLYN's Avatar
BRKLYN
Mine was doing that, changed main unit on Dr side, all work perfect now. Glad I didn’t spend money on actuators.
To Driver's side power lock not locking
