Backspacing question.
Old Apr 9, 2009 | 10:52 AM
540 vette's Avatar
540 vette
Default Backspacing question.
What is the difference between 50 mm backspacing and 54 mm backspacing. Besides 4 mm. Will the 50 mm bring the wheel closer to the hub or will it bring it out towards the outside of the car.
Old Apr 9, 2009 | 11:18 AM
waktasz's Avatar
waktasz
Going higher brings the wheel in, toward the center of the car.
Old Apr 9, 2009 | 11:32 AM
540 vette's Avatar
540 vette
So that means the stock wheel with 54 mm with sit in closer than the 50 mm. How much of a difference is it. I will have a 285-35-18 tire on it.
Old Apr 9, 2009 | 11:34 AM
waktasz's Avatar
waktasz
4mm difference.
Check this out for a visual reference.
edit:
this link is better
http://www.wheelsmaster.com/rt_specs.jsp
Old Apr 9, 2009 | 11:39 AM
540 vette's Avatar
540 vette
Thanks for the link it really dosen't look like muck.
Whats your opinion, would you use them the 50 mm over the 54 mm.
It's a long story that is on another thread of mine to do with tires.
Old Apr 9, 2009 | 12:27 PM
waktasz's Avatar
waktasz
Well stock offset is +58 so a +50 will stick out 8mm more. If you want to run big tires and not rub the fender I'd stay as close to stock size as possible.
To Backspacing question.
