Check engine light 02 vert
Old Apr 12, 2009 | 11:33 AM
ant21b's Avatar
ant21b
Default Check engine light 02 vert
The check engine light on my 02 vert started blinking on and off and the engine was running rough then it just stalled out and would not restart like its not getting any fuel please advise.
Old Apr 12, 2009 | 11:43 AM
mowton's Avatar
mowton
Read attached and dump the codes. Post them so we can get a better idea of your problems. Make sure you post the entire sequence as displayed on the DIC.
http://www.c5help.com/c5_dtc_codes.htm
Old Apr 12, 2009 | 12:21 PM
ant21b's Avatar
ant21b
These are the codes:
10 pcm: p0300c
28 tcs: c1226h,c1287h,c1288h
60 ipc: b0521h
a0 ldcm: b2282h,b2284h,u1064h,u1096h
a1 rdcm: b2205h,b2283h,b2287h,b2285h,b2265h,u1064 h,u1096h
a6 scm: b2605 h c
Old Apr 12, 2009 | 12:41 PM
mowton's Avatar
mowton
P 0300 (C -- Current) is a misfire...fuel or electrical problem whic appears to now be preventing the car from starting.
Here is a good diagnostic article
http://www.gearchatter.com/viewtopic10471.php
To Check engine light 02 vert
