How hard to replace headlight?
Old Apr 12, 2009 | 11:35 AM
WAGONGUY's Avatar
WAGONGUY
Default How hard to replace headlight?
Noticed last night I have a high beam headlight out on my 2000 Corvette. Big job or not to replace? Shoot me some advice.
thanks
Old Apr 12, 2009 | 11:42 AM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
I had to change mine about a year ago and from what I remember it was easy. I'm sure there is a thread around here somewhere on it.
Old Apr 12, 2009 | 12:00 PM
DeeGee's Avatar
DeeGee
Here's the procedure from the service manual. The bezel comes off by removing just 3 screws. You can also select the headlights on and then back off to park to turn the lights off. Just dont hang around or the lights will stow after 10 mins. But its a 10 minute job.
Document ID# 219614
2002 Chevrolet Corvette
________________________________________
Headlamp Bulb Replacement
Removal Procedure
1. Open the hood.
2. Remove the headlamp motor/actuator cover from the ****.
3. Rotate the headlamp motor/actuator manual control **** counterclockwise to raise the headlamp.
4. Disconnect the headlamp wiring harness electrical connector from the forward lamp wiring harness.
5. Remove the headlamp bezel. Refer to Headlamp Bezel Replacement .
Caution
Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury:
o Turn off the lamp switch and allow the bulb to cool before changing the bulb.
o Leave the lamp switch OFF until the bulb change is complete.
o Always wear eye protection when changing a halogen bulb.
o Handle the bulb only by its base. Avoid touching the glass.
o Keep dirt and moisture off the bulb.
o Properly dispose of the used bulb.
o Keep halogen bulbs out of the reach of children.
6. Reach through the opening between the headlamp assembly and the frame rail to access the headlamp bulb/socket.
7. Rotate the headlamp bulb/socket counter-clockwise to remove it from the headlamp capsule.
8. Disconnect the electrical connector from the headlamp bulb/socket.
Installation Procedure
1. Connect the electrical connector to the headlamp bulb/socket.
2. Install the headlamp bulb/socket to the headlamp capsule rotating clockwise until fully seated.
3. Install the headlamp bezel. Refer to Headlamp Bezel Replacement .
4. Rotate the headlamp motor/actuator manual control **** clockwise to lower the headlamp.
5. Connect the headlamp wiring harness electrical connector to the forward lamp wiring harness.
6. Install the headlamp motor/actuator **** cover.
7. Check and adjust the headlamp aim as necessary. Refer to Headlamp Aiming .
8. Close the hood.
The Headlight Bulb is a 9005
To How hard to replace headlight?
