Valve spring install, BDC.
Old Apr 14, 2009 | 01:31 PM
plaster's Avatar
plaster
Default Valve spring install, BDC.
Ready to install rockers after replacing a spring. I used 80 lbs of compressed air, which should have put piston at BDC. Both valves should be closed at this point, allowing me to torque down rockers. Correct?
I know it should be at TDC, but this seems to make sense to me. Granted, I haven't cracked open a valve cover in about ten years.
Old Apr 14, 2009 | 03:44 PM
dwestsr's Avatar
dwestsr
Definitely must be TDC. BDC will have exhaust open and possible intake , depending on cam duration.
Old Apr 14, 2009 | 04:07 PM
lucky131969's Avatar
lucky131969
No offense, but it doesn't make sense to me. Why would you want to use the air method with the piston at it's lowest point? That way you have to have more volume of air to do the same job. Additionally, with the piston at TDC, if the air fails in the process, the valves don't drop into the cylinder.
Old Apr 14, 2009 | 04:35 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Sounds to me like he already changed the valvespring, and now wants the engine rotation at a point where both valves are closed for putting the rockers on.
You can put the rockers on, even if it depresses a valve...just snug the bolts up, then if you find a valve is open...just rotate engine until you see both valves closed, then torque the rocker bolts.
Old Apr 14, 2009 | 05:17 PM
plaster's Avatar
plaster
Exactly right - spring is already on and need both valves closed to torque rockers.
Old Apr 14, 2009 | 05:28 PM
lucky131969
Sorry.....my misunderstanding.........
Old Apr 14, 2009 | 08:45 PM
ZeeOSix's Avatar
ZeeOSix
Yep, too much valve overlap at BDC (due to radical cam timing) so there would be major air leakage to keep the valves closed with springs removed unless you have one insane air compressor.
To Valve spring install, BDC.
