Tpms
Old Apr 15, 2009 | 07:25 AM
VET IT B's Avatar
VET IT B
Default Tpms
Can someone show me a link to getting my 2000 tire sensors reprogramed? I replaced the bateries and can't find the link to get them reprogramed. Thanks, Mark
Old Apr 15, 2009 | 07:41 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
someone will jump in with a link, it's in the owners manual if you have one.
Old Apr 15, 2009 | 04:08 PM
poolboy's Avatar
poolboy
You'll need to use a magnet in place of the tool they mention below - I use one of those magnets on a stick - the kind you get at a hardware store to pick up loose screws and nails...
Reprogramming the Tire Pressure Monitors
1) Turn ignition on.
2) Press "Reset" button in order to clear any IPC display warning messages.
3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank.
4) Press and hold the DIC "Reset" button for 3 seconds.
5) Press the "Options" button again until TIRE TRAINING message appears.
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming.
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem.
8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again). You will have three chances before you must start the entire process over.
9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
To Tpms
