key fob
Old Apr 15, 2009 | 09:14 AM
kbodin's Avatar
kbodin
5th Gear
Default key fob
Key Fob won't hold memory. Bought a new one and still does not hold memory. What could be causing this?
Old Apr 15, 2009 | 09:25 AM
ljthe2nd's Avatar
ljthe2nd
Are your tire pressure sensors working?
Old Apr 15, 2009 | 10:30 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I love this site for all the new stuff I learn everytime I'm on it. Would you explain how the tire pressure sensor plays into key FOB please?
Old Apr 15, 2009 | 10:37 AM
thomastl's Avatar
thomastl
The receiver module located in the back is used to recieve the signal from both the Tire Sensors and the Key Fob and send the signal to the computer.
If the receiver mudule is bad - that would possibly cause both systems to not work properly.
Old Apr 15, 2009 | 10:53 AM
ljthe2nd's Avatar
ljthe2nd
Also if for some reason there is a disruption of power and they both aren't working you have to program the tire pressure sensors first and then you can program the fob.
Old Apr 15, 2009 | 10:56 AM
Eric D's Avatar
Eric D
How common is this issue and can it work sometimes and other times not?
When I get the vett ready each spring to put back on the road, one of the FOB's seems to forget who it is.
Thanks!
Old Apr 15, 2009 | 12:38 PM
poolboy's Avatar
poolboy
When you say it won't hold memory, do you mean that if you hit unlock on the FOB the seat and other stuff does not go to where it should?
Also when you say you bought a new FOB - was it really a new one or a used one?
Do you have another FOB, and if so, does it work?
You may want to check this post out too - http://forums.corvetteforum.com/c5-t...em-solved.html
Old Apr 15, 2009 | 12:59 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
What model is your car?
I have been down this road. Mine is a '99 and was originally the old passive style system. I bought the parts for an '01-'04 model (newer style) fob and reciever and did the swap. solved all my issues. Mine was doing the same thing as yours. I too bought a new fob and it messed up as well.
Old Apr 15, 2009 | 01:07 PM
gpracer1's Avatar
gpracer1
For some reason 2000's love to do this. It usually requires replacing the FOB.
To key fob
