1 7/8" American Racing Header install
Old Apr 20, 2009 | 11:00 PM
B Neat's Avatar
B Neat
Default 1 7/8" American Racing Header install
I've heard the 1 3/4" American Racing Headers install very easily. I bought the 1 7/8" and wanted to know if they are much more difficult to squeeze in.
Old Apr 21, 2009 | 01:20 AM
zoomz's Avatar
zoomz
I should have my 1-7/8 set next week .
Old Apr 21, 2009 | 07:10 AM
montac's Avatar
montac
The install wasn't that bad. The driver's side slipped right in. The passenger side gave me a little more trouble but still not bad. I disconnected the starter wiring to install it and I think the hardest and most painful part of the install was reconnecting everything once the header was in.
Get the car as high as possible to make life a little easier.
Charlie
Old Apr 21, 2009 | 07:29 AM
B Neat's Avatar
B Neat
Is 6 feet high enough? (I have a lift) Did you have to raise the motor for either side?
Old Apr 21, 2009 | 10:05 AM
golfinz's Avatar
golfinz
I didnt touch the motor/motor mounts when I installed my 1 7/8 ARH. The driver side went right in...the passenger side, I had to remove the starter and once the header was in I dropped the header down a few inches to slip the starter back into place. I also removed the coil packs to give me more working room, plus they are easy to get on/off
Old Apr 21, 2009 | 11:38 AM
montac's Avatar
montac
You suck! LOL. Just kidding. Should be cake. I raised the driver side slightly to slip the passenger side header in but I don't think it was really necessary.
Old Apr 21, 2009 | 12:06 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Did they both drop in from the top ?
Old Apr 21, 2009 | 06:31 PM
01vetter's Avatar
01vetter
Check this out. Should help.
http://forums.corvetteforum.com/c5-t...s-learned.html
Old Apr 21, 2009 | 07:00 PM
B Neat's Avatar
B Neat
Thanks for the link dude, that's a great thead.
Old Apr 22, 2009 | 09:39 PM
SteveDoten@ARH's Avatar
SteveDoten@ARH
Premium Supporting Vendor
No they both go in from the bottom if your using a lift you should'nt need to remove the starter just the wires make sure you have someone to hold the ac lines back while you slide the pass side in
To 1 7/8" American Racing Header install
