AEM boost/vacuum gauge
Old Apr 21, 2009 | 02:50 PM
Blow Torch's Avatar
Blow Torch
Default AEM boost/vacuum gauge
I have a AEM digital boost gauge (that also reads vacuum). I installed it a couple weeks ago, and notice now that with the car on, but not running, the vacuum shows 4 (every time; not 3 or 5, etc..)
My question is;
1. Has anyone else experienced this with a digital gauge
2. What are the chances it will affect my boost (4psi off) The obvious would be to check it with a vacuum gauge to compare, but I don't want to pay $$ to check it ONCE
Old Apr 21, 2009 | 03:25 PM
lucky131969's Avatar
lucky131969
My question is;
Geez, a vacuum gage is not expensive. I guess you could really cheap out and return it .
Have you tried disconnecting the vacuum line to the sensor to see if it returns to a zero indication?
slothy's Avatar
slothy
by chance is it like the electronic boost auto meter gauges where you have to hook them up to a uninterrupted power source so it can calibrate while starting car?
Old Apr 21, 2009 | 03:42 PM
Blow Torch's Avatar
Blow Torch
It might not be expensive, but since I haven't used/needed one in 10 years It just seems like a waste to buy one and then leave it on the shelf, and I'm too honest for my own good to use it and return it And BELIEVE me, after being nickled and dimed to death with a SUPERCHARGER install, I've got to save every dime I can just to EAT
I haven't disconnected it yet; I will try it when I get home, but not sure if it will matter, since it shouldn't be "storing" vacuum in the line (not trying to sound smart on that reply)
"by chance is it like the electronic boost auto meter gauges where you have to hook them up to a uninterrupted power source so it can calibrate while starting car?
Not sure Slothy; I read over the installation instructions last night, and didn't see anything. It just says to hook it to a keyed source
I e-mailed AEM a few days ago, but no response yet.
Didn't know if it was a common problem or not
Thanks for the suggestions guys.
Old Apr 21, 2009 | 03:46 PM
slothy's Avatar
slothy
http://autometer.com/productPDF/0569A.pdf
step 8 -
i used the i believe pink wire behind the ignition switch
Old Apr 21, 2009 | 03:47 PM
lucky131969
Did you program the gauge,or just plug it in?
Old Apr 21, 2009 | 04:26 PM
Blow Torch's Avatar
Blow Torch
I just plugged it in
I also should have been clearer. The gauge worked fine for the first week or so. (Did a sweep when you first turn it on, then went back to 0) It also read about the around 22 at cruise then, and around 22 now (although it is obviously fluctuating)
I just noticed the last few days that it does the sweep and returns to 4 instead of 0
Slothy
Mine doesn't plug into a MAP sensor, it runs to an electrical sensor with a vacuum hose on the end that plugs into the vacuum source
I forgot which keyed source I used, but it was the one in the gauge install write up one of the SC vendor shops posted a few weeks back.
Old Apr 21, 2009 | 07:18 PM
Blow Torch's Avatar
Blow Torch
Update
I unplugged the vacuum AND electrical connection with the engine off, fired it up and switched it back off. It the went to "6" when I turned it on
I then unplugged it, fired up the engine, and plugged it up while the engine was running just for some variety. Switched the car off and now it's at "8"
I'm either going to stop on that exercise, or keep doing it until I get it all the way around back to 0!
To AEM boost/vacuum gauge
