Running hot"
Old Apr 24, 2009 | 02:35 PM
redman0204's Avatar
redman0204
Default Running hot"
Did first drive today . coolant temps around 210 to 224 at idle . is that too warm ? cooling fan seem to be working .did coolant flush last year before storeing .
Old Apr 24, 2009 | 03:00 PM
Point & Shoot's Avatar
Point & Shoot
Perfectly normal range when idling in traffic with the A/C off.
With the AC off, the low speed fans come on at 226 & shut off at 216 so you are looking
Old Apr 24, 2009 | 03:23 PM
chaase's Avatar
chaase
St. Jude Donor '12
These cars are designed to run a bit warm. It helps the catalytic converters work better.
Old Apr 25, 2009 | 07:07 AM
Oldvetter's Avatar
Oldvetter
Perfectly normal, this is a common question, here is the lowdown:
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph
Note: for "in-town" driving (under 35 mph) or waiting at a traffic light/drive thru, you can keep your car's temperature lower by turning on the A/C. The fan comes on a 185 F instead of 226 F.
Old Apr 25, 2009 | 05:40 PM
happa's Avatar
happa
Your good man! Normal
To Running hot"
