Hinson Motorsports now stocking Trickflow Cylinder Heads!! (Lots of Eye Candy Inside)
Former Vendor
These are the baddest cathedral cylinder heads on the market!
Trickflow "As Cast" 220cc $1679
Trickflow CNC Ported 215cc $2349
Trickflow CNC Ported 225cc $2349
Trickflow CNC Ported 235cc $2399
Trickflow CNC Ported 245cc $2615
Trickflow CNC Ported 265cc $3950
FREE SHIPPING on 215, 225, 235, and 245 CNC Ported Heads!
Increased Piston to Valve Clearance (13.5* Valve Angle)
- Allows you to run a larger camshaft with more PTV clearance than a stock head
Thick Deck (.600")
- Withstands higher cylinder pressures when using forced induction & nitrous
Extreme Dual Valve Springs
- Rated for .650" Lift
- 450# Open, 150# Closed
Stainless Intake & Exhaust Valves
- Withstands higher exhaust temperatures
6 Bolts Per Cylinder Option (Available on 235cc, Standard on 245cc & 265cc)
- Adds 2 more bolts per cylinder, which will withstand extreme cylinder pressures
During the development stage, Trick Flow engineers determined that the valve angles needed to change from 15* to 13.5*. This change decreased valve shrouding, increased mid-lift airflow, and increased rocker arm-to-valve cover clearance. Testing also proved that relocating the spark plug position in the combustion chamber further enhanced combustion along with mid lift airflow and improved the integrity of the casting in the chamber area. Trick Flow also added additional material to the decks (.600") and to the rocker arm mounting pads to improve high rpm valve train stability.
Thick Deck (.600")
Former Vendor
Flow Numbers
Roller Rocker Arms
Yella Terra Ultralite Shaft Mount Non-Adjustable Roller Rocker 1.7 Ratio (LS1/LS2) $450
The use of roller rocker arms is recommended with cylinder heads having bronze guides. Using roller rockers will reduce the wear on the guides thus reduce oil consumption down the road.
Stock rockers scrub the valve tip above .550" lift, the more you shim a stock rocker, the worse the scrub becomes. A stock rocker should work like a rocking chair to open the valve, which is not at all how a roller rocker works. A stock rocker will have a wide pattern, if you shim it up to reduce the width of the pattern, you will increase the scrub, and this scrub is the source of the friction that causes tip and guide wear. A roller rocker works just the opposite, as you shim it up it reduces the sweep pattern, since it rolls there is no scrub.
Pushrods
Comp Cams Chromemoly Pushrods Starting at $99.99
Available in .025" increments
Comp Cams Pushrod Length Checker $19.99
A .100” longer than stock pushrod is required with these heads.
Head Gaskets
Trickflow "As Cast" 220cc (3.9 Bore)
3.910 Recommended
GM LS1 5.7L Multi-Layer Steel Cylinder Head Gaskets $49.99
Cometic 3.910" Multi-Layer Steel Cylinder Head Gaskets (.040") $159.98
Cometic 3.910" Multi-Layer Steel Cylinder Head Gaskets (.051") $159.98
Trickflow "As Cast" 220cc (4.0 Bore)
4.060 Recommended
GM LS3 6.2L Multi-Layer Steel Cylinder Head Gaskets $69.99
Cometic 4.060" Multi-Layer Steel Cylinder Head Gaskets (.040") $159.98
Cometic 4.060" Multi-Layer Steel Cylinder Head Gaskets (.051") $159.98
3.910 Recommended
4.060 Recommended
4.150 Recommended
GM LS7 7.0L Multi-Layer Steel Cylinder Head Gaskets $75.99
Roller Rocker Arms
Pushrods
Head Gaskets
3.910 Recommended
4.060 Recommended
3.910 Recommended
4.060 Recommended
4.150 Recommended
Former Vendor
Trickflow Heads make huge under the curve power over LS7 Heads
Cylinder Head Testing done by Trickflow
440ci LSX
Trickflow 235cc CNC Ported Cylinder Heads
- 235cc Intake Runner
- 2.080" Intake Valve
262/270 .629/.629 114LSA Camshaft
FAST Intake
10.8 Compression
vs.
Switch to GM LS7 270cc CNC Ported Cylinder Heads
- 270cc Intake Runner
- 2.200" Intake Valve
LS7 Intake
10.8 Compression
Next Test
Swap camshaft to 233/276 .629/.629 107LSA
Our Results
We went with the Trickflow 245cc 6 Bolt Cylinder Heads on our 454 LSX build w/106mm Turbo. They do an excellent job of keeping the extreme cylinder pressure under control. We made 1272 rwhp on low boost with this combination!
We went with the Trickflow 235cc Cylinder Heads on our 427 LS3 NA build. We made 603 rwhp with this combination. Naturally aspirated, pump gas, hydraulic roller!
440ci LSX
FAST Intake
10.8 Compression
vs.
LS7 Intake
10.8 Compression
Next Test
Our Results
you're right up the road from me (2.5 hrs) when i have the extra $ i might just have to order from ya.. out of curiousity, do you know of any good tuner shops around the bham area?
Former Vendor
Seth
205-267-6387
Former Vendor
