Car is throwing code need help
Old Apr 25, 2009 | 03:31 PM
Danny Balon's Avatar
Danny Balon
Default Car is throwing code need help
I have a 97 C5 and it's throwing B0338 HC, it says it's "Inside Air Temperature Sensor Open". Can someone tell me what that means or how to fix it? Thanks!
Old Apr 25, 2009 | 04:11 PM
huttler's Avatar
huttler
It's the inside air temp. sensor next to the ignition key hole. If you took the panel off it's easy to forget to plug the harness back in, i've done it a dozen times
Old Apr 26, 2009 | 03:42 AM
Danny Balon
I popped off the panel next to the ignition but i didnt see any harness just a wire wrapped in foam? Im lost please help!!
Old Apr 26, 2009 | 06:07 AM
99 vett babycar's Avatar
99 vett babycar
there should be a sensor at the end of the wire. did u just get this car?
To Car is throwing code need help
