codes - help please.
Old Apr 25, 2009 | 11:08 PM
Konstantin's Avatar
Konstantin
Default codes - help please.
98 C5
after a header install i got P0327 and P0332, knock sensor circuit front and rear, check engine light is on.
what is it ?
also, for a while i had a C1234 - left rear wheel speed circuit open or shorted - what part needs to be replaced ?
thanks guys !
- Konstantin
PS> car is running super rich right now if it makes any difference, 11.8 A/F. getting it fixed soon tho. Also, LR hub/bearing assy was replaced in 2004, 25k miles ago when C1223 and C1227 came on, just found old invoice from previous owner.
Old Apr 26, 2009 | 10:08 AM
Konstantin's Avatar
Konstantin
anybody ?
Old Apr 27, 2009 | 07:19 AM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Originally Posted by Konstantin
98 C5
what is it ?
thanks guys !
- Konstantin
Check with your installer tuner, did anyone do any intake mods? Car shouldn't be running rich if a proper tune was performed. Your fuel trimming is proabably off. Hopefully the codes for the fuel trims were not shut off.
Old Apr 27, 2009 | 04:54 PM
Konstantin's Avatar
Konstantin
no tune was done yet ( getting it done this wed, wanted before and after dyno ), i replaced the intake with 01+ intake, but that should not change anything. so, a tune can fix knock sensor codes ?
without a tune the car made 326rwhp/340rwtq running 11.8 AFR
thanks, you're right, i should just let my tuner take care of everything, instead of me trying to troubleshoot it, hes good at it.
- Kons
Old Apr 27, 2009 | 05:24 PM
lucky131969's Avatar
lucky131969
Is the knock sensor harness plugged in? Also, it's possible that the harness was pinched under the intake manifold.
Old Apr 28, 2009 | 12:43 AM
Konstantin's Avatar
Konstantin
light does not always come on, 50/50 chance while i drive... might have to take the intake off again.
Old Apr 28, 2009 | 07:05 AM
dougbfresh's Avatar
dougbfresh
You had the intake off??
Old Apr 29, 2009 | 11:30 AM
Former Vendor
Knock sensors are under the intake.
To codes - help please.
